import variables from control expert to vijeo designer
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Showing results forย
Did you mean:ย
  • Support
  • import variables from control expert to vijeo designer
CraigEl
Administrator CraigEl Administrator
35
MikaelKrantz
Kirk MikaelKrantz Kirk
7
Omaelk
Janeway Omaelk
3
chris_clerc
Administrator chris_clerc Administrator
2
Modicon M580
Harmony HMI
Back to Ask the Community
kishore1march
Lieutenant JG kishore1march
Lieutenant JG
Posted: โ€Ž2023-03-27 12:52 PM
4768
Dear,
Iam exporting a DDT from control expert (.XVM format) and importing the same file in vijeo designer v6.2 by using "link variables..." , By this method all the variables are importing in the Vijeo designer variables list, but the tag address are populated as %UV43..... due to this, whenever I re-build my PLC program after modification, the communication error comes in HMI and thus HMI stops communicating with the PLC.
โ€ƒ
Pls suggest me to import variable with the PLC address also (instead of self-generating %UV43...)
Bosswaffle
Lt. Commander Bosswaffle
Lt. Commander
Posted: โ€Ž2023-03-27 01:23 PM
4758
If you check the "HMI variable" checkbox for your variables in Unity/Control Expert they won't get a new internal adress (%UV) when the program is re-built. This is the approach I take if I link the variables.
You should also be able to export your variables as a .txt file. Importing that into vijeo (instead of linking the variable mapping file) should result in all %MW address, I don't remeber how that handles DDTs however...
If you really want to use %MW then you should be able to re-create the DDT as a user data type in vijeo and create instances and assign the correct %MW.
kishore1march
Lieutenant JG
Posted: โ€Ž2023-03-28 01:13 PM
In response to Bosswaffle
4745
Hi Boss,
Thanks for the time and input.
I have already faced this issue in 2016 with importing DDT's, but i thought it would have been rectified by now.
Unfortunately still it is the same conditions.
If schneider address this issue. it would be a great time saving during developing larger application. ๐Ÿ˜
Just my thoughts and suggestion.
Bosswaffle
Lt. Commander
Posted: โ€Ž2023-03-31 05:35 AM
In response to kishore1march
Maybe Operator Termianl Expert, or whatever the new name for Vijeo XD is will be better! Unfortuantley the last time I tried it it didn't have half as many features as Vijeo Designer.
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
