MNB-1000 set up
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • MNB-1000 set up
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Krobbins
Krobbins
Cadet
Posted: ‎2023-03-30 05:23 AM
3585
MNB-1000 set up
We have a new to us MNB-1000.  We had not luck seeing it with WPT commissioning tool, so set it back to factory defaults.  No change.  WPT is not giving any errors or popups.  We have tried both RJ45 ports, I think the lower one is ethernet, but have not been able to confirm this.
Solved: MNB-1000 Set IP after factory reset - Communities  is very close to our issue, but we are not getting any pop up error messages.
When we use WPT on network with our running MNB-1000s and Jaces, they all show up in the commissioning tool.
If we plug into the MNB-1000 with a PC running wireshark on it, should we see anything?  We didn't, could this be due to ICMP being disabled?  This is not meant as a red herring, just without the ability to ping, how can we determine if the MNB-1000 can communicate at all?
CraigEl
Posted: ‎2023-03-30 05:26 PM . Last Modified: ‎2023-03-30 10:19 PM
3564
After a reset or fresh from the factory the MNB-1000 IP and MS/TP ports are disabled. The Ethernet port is the only port enabled. You need to set WPCT to BACnet Ethernet to access the MNB-1000 controller via its Ethernet port. Once you have gained access, its BACnet/IP port can then be enabled.
Set up Ethernet communications in WorkPlace Commissioning Tool as follows:
  1. Open the File menu and select Connect to open the Communications Settings dialog box
  2. Verify that the BACnet radio button is selected.
  3. If you need to change timeout settings, click Advanced. The Advanced Settings dialog box opens
  4. In the Communications Settings dialog box, click Change.
  5. In the BACnet Communications Settings-Protocol dialog box click the Ethernet radio button, and then click Next to continue.
  6. Review the information and settings in the BACnet Communications Settings-Ethernet Protocol dialog box  select a different interface if necessary, and then click Finish.
  7. The Communications Settings dialog box appears. Verify the settings shown, and then click Change to revise the settings or OK to accept. TinyTake31-03-2023-11-25-23.png
Krobbins
Krobbins
Cadet
Posted: ‎2023-03-31 05:21 AM
In response to CraigEl
After following those steps, a few times, I select communications pull down, then 'browse', show all devices, browse settings....network or global?  Nothing shows up in the window, either way, '0 devices found'.
Should the dip switches all be off?
Laptop is set to 10.1.10.212 with ethernet cable plugged into upper RJ45 port on MNB.
I don't know if I am doing something wrong or we have a bad device.
Thanks for your help.
