Send InviteCancel
Posted: 2024-02-2806:18 AM
SRT1000XLI Site Wiring Fault
I get this on the display (in orange) when I change the Phase and N wires to the input of the UPS. What is the cause? I have no influence on the wiring of the wall outlet the UPS get it's power from.
The SURT1000XLI does not show this kind of behavior.
Posted: 2024-03-0302:31 PM
Firstly why would you switch the phase and neutral wires?
Secondly there is no pictures to show the alert you are getting.
Thirdly the SURT1000XLI does not have a digital interface to show issues nor does it have a light that shows wiring faults. That does not mean that it is not there though. If you have a network card in it it would show up there.
I can only assume that the warning you are talking about is to tell you that your phase and and neutral wires are switched. Reversing the phase and neutral wires can create a safety hazard, especially if the circuit is not properly grounded. In such cases, electrical appliances and devices may have exposed metal components that become live, increasing the risk of electric shock.
