P5F30 with Modbus/TCP communication with PLC M580
Metering & Power Quality
  • EcoStruxure Power & Grid
  • P5F30 with Modbus/TCP communication with PLC M580
Charles_Murison
Picard Charles_Murison Picard
529
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
139
Ramasamy_N
Captain Ramasamy_N Captain
115
Modicon M580
afvanin
afvanin
Cadet
Posted: ‎2023-05-26 10:58 AM
3537
Hello, how are you all?
I'm making an application with an M580 and a P5F30 relay in ModbusTCP communication. I would like to know if there is any control block ready to be used in the PLC logic. Grateful
  • Thumbnail of Modicon M580
    Modicon M580
View products (1)
Mnabil
Lieutenant JG Mnabil Lieutenant JG
Lieutenant JG
Posted: ‎2023-05-29 05:05 AM
I think that Generic Modbus DTM will be suitable but please check that the communication on P5 side is active
Replies 4
Mnabil
Lieutenant JG
Posted: ‎2023-05-27 04:00 AM
3524
Hello Afvanin,
you have two methods,
the first approach is to use DTM and add a Modbus device on DTM browsers, then add a request to pull "Read" the data.
The second approach , uses one of communication blocks like Read_Var Block to read the data from P5 Relays , for more details please check the attached pdf
afvanin
afvanin
Cadet
Posted: ‎2023-05-29 04:40 AM
3509
Hi @Mnabil.
Is there any specific DTM for the P5, or should I use the Generic Modbus DTM? Because I believe that doing it through the DTM, it is simpler to carry out the logic, instead of using READ_VAR.
Thank you very much!
Mnabil
Lieutenant JG
Fabian_Decobecq
Ensign Fabian_Decobecq Ensign
Ensign
Posted: ‎2025-05-01 12:13 AM
Complex part is the control with open or close select object1 (registers 22500=1 or 22501=1) before execute selected type with register 22502 = 1.... it doesn't work sometimes.... We use READ_VAR and WRITE_VAR into our custom DFB Block
