MNB-V2 Inlet Size
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • MNB-V2 Inlet Size
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Posted: ‎2022-03-02 11:52 AM
1
1362
MNB-V2 Inlet Size
Isn't there a parameter for configuring the duct inlet size for VAV box controllers (V2's), so that it can calculate the air flow correctly? Where is that found, in the balancer tool?
CraigEl
Posted: ‎2022-03-02 02:43 PM
You don't input the inlet size, you input the Rated Box flow at 1" WC. See attached page from the Commissiong Tool and Flow Balance Tool User guide. This value is often found on a sticker on the side of the box or in the flow data in the box specifications. If you can't find this information you may need to contact the box manufacturer.
CraigEl
