MNB-1000 Set IP after factory reset
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • MNB-1000 Set IP after factory reset
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
wintejs
wintejs
Cadet
Posted: ‎2023-01-24 02:38 PM
3176
I have 2 MNB-1000 controllers that are factory reset. I need to re-address them to a new IP and configure the units for spares. I am not able to get to the configuring windows using Workplace Commissioning Tool.  I have set my laptop to 10.1.10.44 with subnet at 255.255.255.0 with no success.  My software version is 5.8.6.1781.  At the moment I am using the demo mode, would that be an issue.  What am I missing?  Thank you.
jsw
CraigEl
Posted: ‎2023-01-24 06:54 PM
In response to wintejs
3154
I suggest you review https://community.se.com/t5/Building-Automation-Knowledge/Workplace-Tech-5-10-1-Rtmonitor-exe-Error/...
and/or
https://community.se.com/t5/Building-Automation-Knowledge/WorkPlace-Commissioning-Tool-Windows-7-quo...
Replies 4
CraigEl
Posted: ‎2023-01-24 04:00 PM
3165
After a reset or fresh from the factory the MNB-1000 IP and MS/TP ports are disabled. The Ethernet port is the only port enabled. You need to set WPCT to BACnet Ethernet to access the MNB-1000 controller via its Ethernet port. Once you have gained access, its BACnet/IP port can then be enabled.
See https://community.se.com/t5/Building-Automation-Knowledge/MNB-1000-not-accessible-via-default-IP-add... for further information
wintejs
wintejs
Cadet
Posted: ‎2023-01-24 05:32 PM
In response to CraigEl
3161
Thank you for your timely response.  I am connecting directly from my work laptop to the MNB-1000 with a ethernet cable and I get the attached pop-ups. It appears that an adapter is needed to interface with, if so, is there a part number for this. As you can tell, I am new to this BACnet protocol.
CraigEl
3155
and/or
wintejs
wintejs
Cadet
Posted: ‎2023-01-25 06:49 AM
The second link was the fix. Thank you!
