Is it possible to create custom measurement and make it available in Power Monitoring Export Report tab?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Is it possible to create custom measurement and make it available in Power Monitoring Export Report tab?
Charles_Murison
Picard Charles_Murison Picard
523
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
EcoStruxure™ Power Monitoring Expert
Tabs
Ensign Tabs
Ensign
Posted: ‎2023-02-07 05:59 PM
2060
Hi, everyone.
We have a problem displaying custom measurement to web application report tab of PME (v2022). Our system is an integration of PO and PME.
Picture below is my sample configuration of my custom Measurement and Device type.
In the Ethernet Device Configuration, we can confirm that we successfully created a custom Device Type,.
But when we check the report tab in web application, the custom measurement is not available.
Custom Measurement is unavailable in Web applicationCustom Measurement is unavailable in Web application
Is it possible to create custom measurement and make it available in Power Monitoring Export Report tab? or we miss out an important configuration to display the measurement?
Thank you.
  • Thumbnail of EcoStruxure™ Power Monitoring Expert
View products (1)
Tags (2)
  • custom device type
  • custom measurement
henrique_lopes
Lieutenant | EcoXpert Master henrique_lopes Lieutenant | EcoXpert Master
Posted: ‎2023-04-11 09:42 AM
Hello! Did you configure the logging parameters in Tools -> Configure Software Logging? Maybe your driver is only reading information and not writing in database...
henrique_lopes
