Infinet to BACnet Communication
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Send InviteCancel
Posted: 2023-03-0111:00 AM
Using a bCX1-CR and ethernet to 3rd party BACnet controllers I can only establish communication via programming in the workstation. I'm unable to make Programs in the bCX1 and when I try to write to BACnet from an infinet controller it says ~"not on the same network".
Shouldn't I be able move data between networks without relying on the workstation?
Thanks in advance.
a. Only moving about 10 points between systems.
b. Will follow best practices for reduced/optimal network traffic.
c. Continuum is ver. 2.00.020150811, Infinet 9900 ver 1.500030, bCX1-CR SW 4.500088 FW. 4.500047
