How to use DI/AI/DO inputs/outputs in Control Expert
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • How to use DI/AI/DO inputs/outputs in Control Expert
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
EcoStruxure™ Control Expert
Modicon PLC Configurator
Back to Ask the Community
gretarmark_
Ensign gretarmark_
Ensign
Posted: ‎2022-12-06 07:33 AM
5770
Hi there,
Usually my company have been using the register addresses %I0.2.0.0, %I0.2.1.0,... for digital inputs, and the OPERATE blocks for analog inputs using e.g. the ST command DAEI03_straumtaka._CH_VALUE:=%IW1.0.2;. In my project, it seems like I cannot use these %I addresses, but instead I have to use EIO2_d1_r0_s2_DDO6402K.DIS_CH_OUT[0].VALUE;
My question is: Do I have to use these array values? Is this something new in Control Expert? How can I be able to use e.g. %I0.2.0.0 instead of array struct names? 
In the image below, you can see the red underline error. I would like to get rid of that, but don't know how.
In another project I have, there is no red underline error as you can see in the image below
The device DDT of the DI unit in my project is shown below
and the device DDT in the other old project I have is as follows
I'm wondering how I should use the DI, DO, and the AI units and i'm not sure if I am doing something wrong or not.
Here is the PLC I am using in my project
and for the other project:
Best regards,
Grétar Már
ajordan
Crewman ajordan
Crewman
Posted: ‎2022-12-06 12:28 PM
5758
Each module uses a structure that represents inputs, outputs, control, and diagnostic data. The structures can be represented using:
  • Topological addressing / IODDT.
  • Device DDT.
When you insert an I/O module on a rack in Control Expert, the type of addressing appears in the bottom of the New Device dialog box. Choose between the following:
  • I/O data type: Topological (default).
  • I/O data type: Device DDT.
NOTE: If you want to change the type of addressing you selected when you added an I/O module to your application, delete the module from your application and then insert the module again selecting the appropriate addressing type.
ajordan
Crewman ajordan
Crewman
5759
  • Device DDT.
gretarmark_
Ensign gretarmark_
Ensign
Posted: ‎2022-12-07 05:44 AM
In response to ajordan
Hey ajordan,
Thank you for the answer! When I remove one module and want to add it again, it is not possible for me to choose between Topological or Device DDT addressing as you can see in the image. It looks like I have to use the Device DDT I/O data type.
P.s. I am using Modicaon 580 HSBY.
