Device (BCPM) name changing in PME/SQL
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Device (BCPM) name changing in PME/SQL
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
mickkennedy
Ensign mickkennedy Ensign
Ensign
Posted: ‎2025-06-12 08:07 AM
476
Recently ran the approved script in SQL Management studio (PME 2023) to change the group.name of a BCPM device, both device name and display name.so basically changed the device name in SQL and PME.
this worked fine and name changed successfully, but when i navigate down to the individual logs from a single  channel of the BCPM, it still displays the old name?
Could anybody advise why this is, and if possible how i can rectify this.
Charles_Murison
Picard Charles_Murison Picard
Posted: ‎2025-06-26 05:27 PM
Hello @mickkennedy ,
Once data is logged in the database, the device name is fixed unless there are actions to change the name. Likely the script you were using has hard coded instructions to change name of a specific source, rather than changing the names of all sources that contain X.
BCPM device driver has built in syntax to take device name and generate additional sources, !!device_name!!_PNLYY_CHZZ@XXXXXX. Where XXXX, YY ZZ could vary depending on the register.
Likely the script used is very speific and looks for Old Device name only, not devices starting wih Device name. Replacing names would be a little more tricky and likely would need to use more complex commands than simple replace AAAAA.BBBBB for CCCC.DDDDD.
Charles
