Building Operation Software Administrator - Stopping
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Building Operation Software Administrator - Stopping
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Jikku
Ensign Jikku
Ensign
Posted: ‎2023-01-24 08:58 AM
5266
Hi Team,
My enterprise server status is showing as stopping however its not stopping for a while and hence I`m not able to login. Attaching the photo for your reference.
Please help to resolve this issue.
CraigEl
Posted: ‎2023-01-24 10:30 PM
If you don't need the EC then I'd suggest it be uninstalled. To reset the password you will need to contact support, see https://community.se.com/t5/Building-Automation-Knowledge/Forgotten-or-unknown-password/ta-p/4368
Replies 10
CraigEl
Posted: ‎2023-01-24 02:26 PM
5246
Please post the trace.log. The server logs are stored in the database folder. The full path depends on the software installed, and if the default path is used:
%ProgramData%\Schneider Electric [EcoStruxure|StruxureWare]\Building Operation [n.n]\Enterprise [Server|Central]\db\logs
Jikku
Ensign Jikku
Ensign
Posted: ‎2023-01-24 08:37 PM
In response to CraigEl
5234
Hi Craig,
Attached is the trace log for your reference. Please advise,
trace.log
CraigEl
Posted: ‎2023-01-24 08:56 PM
In response to Jikku
5231
I've just noticed in your photo that you have an Enterprise Central install but you mention Enterprise Server. Seems like you have installed an EC by mistake.
Jikku
Ensign Jikku
Ensign
Posted: ‎2023-01-24 09:03 PM
For this project I`m only using Enterprise server, since I was not able to login repeatedly, I tried to stop and start the ES and ever since its stuck. i was able to login for the last 24 days and suddenly this issue occurred yesterday.
CraigEl
Posted: ‎2023-01-24 09:09 PM
5224
 I refer you back to your screenshot where I've highlighted the EC install.
I suggest that you uninstall the EC and see where you land.
Jikku
Ensign Jikku
Ensign
Posted: ‎2023-01-24 09:25 PM
Hello Craig,
I`m not able to uninstall the EC from system. No other folders are open yet it shows the same. Are there any other applications or services are to be stopped from windows?
CraigEl
Posted: ‎2023-01-24 09:40 PM
1
5212
Make sure that you have a backup of the ES database and stop both the EC and ES. Note that you will need to go to the Enterprise Server tab of the Software Administrator to stop it.
https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=10651
Jikku
Ensign Jikku
Ensign
Posted: ‎2023-01-24 10:01 PM
I was able to reinstall the ES and EC and now both systems are running. However not able to login to ES through localhost. Is there any way to reset the password for ES.
CraigEl
Glenn13_12
Glenn13_12
Cadet
Posted: ‎2025-03-12 08:16 PM
hello i want to connect to the server but the server say not installed
