ACX 5740 Communication Failure
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • ACX 5740 Communication Failure
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
cpmacdon
Crewman cpmacdon
Crewman
Posted: ‎2022-03-08 08:45 AM
2639
I am an end user/owner of a Schneider Electric access control system.  We have recently (within the last month) had three ACX5740 door controllers fail, all in the same manner.  Basically the unit appears off line in the system, door access is not functional, unable to communicate.  All LED's appear normal, units still respond to a PING, but I was unable to get them to return to Online status.  I first attempted the RAM clear, no luck.  I then performed an IP reset, unit will still respond successfully to a PING, but I am unable to connect to the configuration page through a web browser even when plugged directly into my laptop.  Any suggestions you can offer regarding how to fix this issue, and what may cause this to happen, would be greatly appreciated.
cpmacdon
Crewman cpmacdon
Crewman
Posted: ‎2022-05-09 09:37 AM
In response to CraigEl
Thanks Craig!
As it turns out, the controller failures were caused by a network security scan that our IT team had switched to.
Long story short, Greenbone network security scan utility causes irreversible damage to ACX 5740 controllers.
CraigEl
Posted: ‎2022-03-08 01:55 PM
1
2619
You should probably contact your local SE office or EcoXpert and book a service visit. One failure can be seen as bad luck, but three makes me think it's something related to the environment or installation.
cpmacdon
Crewman cpmacdon
Crewman
Thanks Craig!
