how can I generate a report in Plant SCADA with Start & End Date & Time exported to Excel?
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • how can I generate a report in Plant SCADA with Start & End Date & Time exported to Excel?
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
AVEVA
AVEVA™ Plant SCADA
Back to AVEVA Plant SCADA Forum
Dilhan
Ensign Dilhan
Ensign
Posted: ‎2025-09-17 01:32 AM
652
I need to generate a report in Excel using Plant SCADA 2020. Most resources I’ve found rely on Calendar Control and Date/Time Picker in ActiveX, but these are not available in the 2020 version. As a workaround, I used the Calendar Genie for date selection, but I cannot find any functions related to time input.
Since I need to provide both Start Date, End Date, and Start Time, End Time, how can I generate a report in PLANT SCADA with Start & End Date & Time exported to Excel?
  • Graphics Builder
  • Industrial Graphics
  • Plant SCADA Anywhere
  • Plant SCADA Runtime
  • Workspace
  • report in Plant SCADA
olivier_vallee
Commander
Posted: ‎2025-09-21 10:30 PM
613
Hi @Dilhan
Just one small correction, there isn't a 2020 version of Plant SCADA, I believe you must be referring to "Plant SCADA 2020 R2". To the best of my knowledge there isn't any reason why the Calendar Control or Date/Time picker ActiveX controls would not be available. It might be worth double checking.
Ultimately you should be able to achieve what you want with a String tag on the page with the operator able to enter date and time information. Then the generate report button could use these an inputs. Or the report itself could use the String variables to define the data range.
The following is guidance from a GPT (please treat all information on face value, fact check and test any suggestions, and this information is shared without any warrantee or guarantee - use at your own discretion):
To generate a report in AVEVA Plant SCADA (formerly Citect SCADA) with dynamic start and end date/time parameters, exported to Excel, you can use a combination of built-in reporting features, Cicode functions, and user input controls like ActiveX calendar and date/time pickers. This allows flexibility for users to select times via tags or forms, and output data (e.g., trends, alarms, or custom data) to a CSV file, which can be easily opened and formatted in Excel.
1. Set Up User Input for Start and End Times (Using Dynamic Tags and ActiveX Controls)
  • Use ActiveX controls for intuitive date and time selection:
    • Add the "Microsoft Calendar Control" (MSCAL.OCX) ActiveX object to a graphics page for date picking.
    • Add the "Microsoft Date and Time Picker Control" (MSDTP.OCX) for time selection.
    • Link these to dynamic tags (e.g., StartDateTag as STRING for date in "DD-MM-YYYY" format, StartTimeTag as STRING for time in "HH:MM:SS" format, and similar for end values).
  • Alternatively, create a Cicode form for manual input. Example Cicode for a simple date selection form (adapt for time):
    text
    STRING sdate, edate, Em, D, M, Y;
    D = DateDay(TimeCurrent());
    M = DateMonth(TimeCurrent());
    Y = DateYear(TimeCurrent(),1);
    sdate = "Start Date";
    edate = "End Date";
    FormNew("Select Report Date", 38, 2, 16);
    FormInput(20, 0, "DD-MM-YYYY Format", Em, 20);
    FormComboBox(2, 0, 15, 6, sdate, 1);
    FormAddList(D + "-" + M + "-" + Y);
    FormButton(8, 1, "Select", 0, 1);
    FormButton(16, 1, "Cancel", 0, 2);
    FormRead(0);
    // Convert to full start/end strings
    STRING START_DATE_TIME = Y + "-" + M + "-" + D + " 00:00:00";  // Add time as needed
    TagWrite("StartDateTag", START_DATE_TIME);  // Store in dynamic tag
    • Extend this for time by adding separate inputs or pickers, then combine date + time using StrToDate() + StrToTime().
2. Configure the Report in Plant SCADA
  • Open the Report Editor in the Plant SCADA Project Editor.
  • Define the report content using placeholders for parameters (e.g., {1} for start time, {2} for end time).
  • Example report format for a trend or alarm summary (saved as "MyReport.rpt"):
    text
    [Report Header]
    Report Generated: [Date] [Time]
    [Trend]
    Tag = YourTrendTagName
    Start = {1}  // Dynamic start time parameter
    End = {2}    // Dynamic end time parameter
    Period = 60  // Sampling interval in seconds (dynamic via tag if needed)
    Samples = 360  // Number of samples (e.g., 6 hours at 1-min intervals)
    [Alarm Summary]
    Start = {1}
    End = {2}
    Category = *
    State = *
    • For custom data, include tag values, SQL queries (if using a database device), or other sections like [Tags] or [Events].
  • Configure the output to file in the report properties (e.g., comma-separated for CSV compatibility).
3. Run the Report Using Cicode with Dynamic Parameters
  • Trigger the report from a button or event using the RunReport() Cicode function.
  • Pass start/end times from tags as strings in the system date/time format (e.g., "YYYY-MM-DD HH:MM:SS").
  • Example Cicode function (call this on button press):
    text
    FUNCTION GenerateDynamicReport()
        STRING StartDate = TagRead("StartDateTag");  // e.g., "2025-09-22"
        STRING StartTime = TagRead("StartTimeTag");  // e.g., "08:00:00"
        STRING EndDate = TagRead("EndDateTag");
        STRING EndTime = TagRead("EndTimeTag");
        // Combine into full timestamps
        REAL StartTimestamp = StrToDate(StartDate) + StrToTime(StartTime);
        REAL EndTimestamp = StrToDate(EndDate) + StrToTime(EndTime);
        // Convert back to strings for parameters (if needed for report)
        STRING StartStr = DateToStr(StartTimestamp, 0) + " " + TimeToStr(StartTimestamp, 0);
        STRING EndStr = DateToStr(EndTimestamp, 0) + " " + TimeToStr(EndTimestamp, 0);
        // Run the report and output to CSV (opens in Excel)
        INT Result = RunReport("MyReport", "C:\Reports\MyReport.csv", 1, StartStr, EndStr);  // 1 = output to file
        IF Result = 0 THEN
            Message("Report Generated", "Report saved to C:\Reports\MyReport.csv", 0);
        ELSE
            Message("Error", "Failed to generate report. Error: " + IntToStr(Result), 0);
        END
    END
    • RunReport(report_name, file_name, output_mode, param1, param2, ...):
      • output_mode: 1 for file, 2 for printer, etc.
      • Parameters match the {1}, {2}, etc., in your report file.
    • For trend-specific exports without a full report, use TrnExportCSV():
      text
      TrnExportCSV("C:\TrendData.csv", StrToDate(StartDate) + StrToTime(StartTime), 60, 360, "*", 0);  // * = all trends, 60s interval, 360 samples
4. Export to Excel
  • Output as CSV (comma-separated) for direct compatibility with Excel. Plant SCADA doesn't natively create .xlsx files, but CSV works seamlessly—open in Excel and save as .xlsx if needed.
  • For true Excel formatting (e.g., charts, formulas), integrate with VB/.NET via VbCallRun() or use AVEVA Reports:
    • In AVEVA Reports, connect to Plant SCADA as a data source (via OPC UA/DA, ODBC, or files).
    • Define a report with start/end time filters (fixed or dynamic via web portal).
    • Generate and export directly to Excel (.xlsx), PDF, or HTML.
    • Example: Set "Start Date and Time" in the report definition for fixed periods, or use runtime prompts for dynamic selection
Dilhan
Ensign Dilhan
Ensign
Posted: ‎2025-09-22 09:10 PM . Last Modified: ‎2025-09-22 09:15 PM
In response to olivier_vallee
These are the Microsoft ActiveX controls I have. When I click on another Microsoft control, I get this message.
olivier_vallee
Commander
Posted: ‎2025-09-23 10:02 PM
Hi @Dilhan
It looks like you don't have the required Microsoft license to use those Microsoft ActiveX controls. My understanding is that you must have a valid Microsoft Office license to make use of these controls.
Kind regards
Olivier
