Faceplates not showing
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Faceplates not showing
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
XavierVilabril
Crewman XavierVilabril
Crewman
Posted: ‎2025-10-01 09:26 AM . Last Modified: ‎2025-10-01 10:23 AM
477
My Plant SCADA project has it's equipments and respective faceplates configured as indicated by the documentation, however, the faceplate field shows "Faceplate not available" when the equipment is clicked. The name of the equipment, however, shows up above where the faceplate would be. On the Example_SA project, everything works fine.
I believe it might be an issue with my citect.ini. The file is attached. For privacy reasons, the actual project name was replaced with "PROJECT".
Could I be missing something on my ini file? Or is it something else?
EDIT: I noticed I get this error whenever I click an equipment:
2025-10-01 18:12:32.404 +01:00 [Error] Workspace::_Workspace_GetPagesForAutoFill: The specified equipment context 'EMS1.PP1.QEPP1.QE2411A_A15' no longer exists.
Thank you.
  • Plant SCADA Runtime
  • Plant SCADA Studio
  • Workspace
olivier_vallee
Commander
Posted: ‎2025-10-02 06:49 PM
Hi @XavierVilabril
I'd recommend checking the following:
  1. Faceplate Association Missing or Incorrect:
    • Faceplates are pages linked to equipment types in the equipment editor. If no page is associated with the equipment type (e.g., the type for QE2411A_A15), the system displays "Faceplate not available."
    • Even if configured per docs, there might be a mismatch in the page name, or the associated page isn't included in the project or compiled properly.
  2. Equipment Model or Tag Generation Issue:
    • The error "Workspace::_Workspace_GetPagesForAutoFill: The specified equipment context 'EMS1.PP1.QEPP1.QE2411A_A15' no longer exists" suggests the full equipment hierarchy isn't fully resolved or available at runtime. This can happen if:
      • The equipment wasn't updated in Plant SCADA Studio, leading to missing tags or incomplete database entries.
      • There's a hierarchy problem (e.g., a parent like QEPP1 isn't defined or has errors).
  3. Project Includes or Library Missing:
    • The Example_SA project works because it includes the Situational Awareness Library (SA_Library), which provides the faceplate templates and autofill logic. If your project doesn't include this library (or the relevant faceplate pages), faceplates won't load.
    • Check if your project is set up as an SA project or if the SA components are properly referenced.
Let us know how you go.
Kind regards
Olivier
olivier_vallee
Commander
Hi @XavierVilabril
Kind regards
Olivier
XavierVilabril
Crewman
Posted: ‎2025-10-03 01:44 AM
I found the issue, I/O server wasn't properly setup for the EMS1 cluster. Thank you for your help!
