Label Replacement in Equipment Names
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Label Replacement in Equipment Names
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
XavierVilabril
Crewman XavierVilabril
Crewman
Posted: ‎2025-09-19 09:27 AM
229
In my system, I have a label that replaces alarm areas with numbers.
Example: PT4 -> Area = 10
However, now I am adding equipment names with the structure: PTx.Board.Load_Cell and I am getting this error:
28 ERROR EQUIP C:(...)_PT4\TsDig.DBF Syntax error (E2020) Line[1]:{10}
I am guessing it is replacing the Label in the equipment names.
I have the solution in mind of adding an _ to all the areas so it will instead replace _PTx, but this will be a rather lengthy implementation. Is there a simpler way (like a setup editor parameter I can change) to avoid this?
Thank you.
  • Alarms
  • Plant SCADA Studio
olivier_vallee
Commander
Posted: ‎2025-09-21 05:01 PM
Hi @XavierVilabril
I'm not aware of a simpler way to fix this issue. It is best to ensure uniqueness when using labels so that you don't encounter issues like the one you experienced. Also note there are reserved or key words that should not be used. See reserved words for more details: https://docs.aveva.com/bundle/plant-scada/page/1064760.html
You could experiment with the Find/Replace tool to help speed up the long modification process.
Best of luck.
Kind regards
Olivier
