How to configure Sequence of events in plant scada
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • How to configure Sequence of events in plant scada
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
Sesa460428
Crewman Sesa460428 Crewman
Crewman
Posted: ‎2025-09-20 06:40 PM
241
We are in the process of replacing two third-party HMIs with Aveva Plant SCADA and will be supplying two new Aveva Plant SCADA HMIs.
The existing SCADA system currently stores time-stamped events, and the customer has requested that we provide the same functionality in the new Aveva Plant SCADA system.
We have configured PLC-to-SCADA communication using OFS, and communication with the PLC is established.
Could you please advise on the best way to display time-stamped events in Aveva Plant SCADA? Additionally,
Is there a standard event management feature available in Plant SCADA, or could you provide a step-by-step procedure for implementing this functionality?
  • Alarms
  • Plant SCADA Studio
  • Reports
olivier_vallee
Commander
Posted: ‎2025-09-21 04:57 PM
Hi @Sesa460428
The latest version of Plant SCADA has project templates that include pre-built pages for alarm display, including Sequence of Event functionality (SOE).
The first step is to create an alarm for the points of interest in your system. E.g. pump starting, valve opening, etc. You need to define the name, type, category, etc.
See this section for more details: https://docs.aveva.com/bundle/plant-scada/page/1068415.html
Once the alarms are defined, the operator of the system can navigate to the alarm page (active alarms) or the SOE page, to see the alarm state changes and details.
If using equipment, you can also make use of the SA Templates, which have functionality to open trends, alarm views when selecting equipment on the display. See the ExampleSA and run it for some demonstrations of these features.
Let us know if there is anything else we can do to assist.
Kind regards
Olivier
