connect between 2 aveva plant scada server and can read and write in the two server from the same runtime
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • connect between 2 aveva plant scada server and can read and write in the two server from the same runtime
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
saramorsy
saramorsy
Cadet
Posted: ‎2025-05-20 12:02 AM
7570
connect between 2 aveva plant scada server and can read and write in the two server from the same runtime also if i need the local server can write and read and the remote server read only  , what is the best way for each ?
  • Communication Drivers
  • Plant SCADA Anywhere
  • Plant SCADA Runtime
  • Plant SCADA Studio
Replies 5
olivier_vallee
Commander
Posted: ‎2025-05-21 11:00 PM
Hi @saramorsy,
It isn't exactly clear what you are trying to achieve. Can you provide more details? Is it two seperate, independent systems? You could look at combining the two systems into one, and run on the two Servers as previously, this would allow sharing of data seamlessly between the two.
Otherwise, you could look at using OPC Client and OPC Server capabilities to share data between the nodes, if you want to keep them separate.
saramorsy
saramorsy
Cadet
Posted: ‎2025-05-29 05:59 AM
I have two water stations, and each station is running its own AVEVA Plant SCADA system. I want to be able to monitor both stations from each other in runtime — meaning, from Station 1, I want to see the data from Station 2, and vice versa.
I'm considering using clustering — creating Cluster1 for Site 1 and Cluster2 for Site 2 — and then combining them into a single project that allows both sites to view each other.
Each site has its own static IP address, and the distance between the two sites is about 20 km.
How can I implement this setup using AVEVA Plant SCADA?
olivier_vallee
Commander
Posted: ‎2025-06-02 02:42 PM
Hi @saramorsy
Thanks for providing additional information.
I think as you have suggested, combining the two projects into one, then run this new unified project on both sites would be the best approach, allowing you to see data from each system and vice versa.
With regards to how to implement this, it can depend on the templates and complexity of your projects. You could simply create a new project called "CombinedProject" then include the two site projects underneath. Compile and see what errors you have and resolve them.
Another approach could be to export all config from one site, and import it into the other site, but that could take some time and be labor intensive.
Let me know how you go.
AidasM
AidasM
Cadet
Posted: ‎2025-06-02 09:53 PM
Hi @saramorsy
Yes it is possible to include two clusters projects into Global Project. Please look information into Citect SCADA documentation versions v.5.5 , v.6.0 , v.7.0 with tags Global Include Project or Global Display Project and You find all info what you need with explanation.
AidasM
AidasM
Cadet
Posted: ‎2025-06-02 10:04 PM
Hi @saramorsy,
