VIJEODESIGNER APPLICATION COMMUNICATING BUT SHOWING EXCLAMATORY ERROR SYMBOL TOO.
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
Select a Country
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • VIJEODESIGNER APPLICATION COMMUNICATING BUT SHOWING EXCLAMATORY ERROR SYMBOL TOO.
olivier_vallee
olivier_vallee
38
Oncom
Oncom
6
stuartm
stuartm
2
Modicon M580
Harmony iPC
Back to AVEVA Plant SCADA Forum
kishore1march
kishore1march
Contributor
Posted: ‎2023-04-02 12:45 PM
1902
Dear,
Iam communicating Schneider IPC with M580 PLC. Here the communication is established and the values are displaying. But iam also getting exclamatory mark error symbol in all the designs that was created.
Refer attached picture.
Kindly help me with feasible solution.
Software - vijeo designer v6.2sp11
  • Industrial Graphics
SEStig
SEStig Contributor
Contributor
Posted: ‎2023-04-03 08:55 PM
1884
Is it actually animating properly (values change when they are supposed to etc)?
Are you using located addressing or unlocated addressing to the M580?
If you are using unlocated, are you using the Data Dictionary?
kishore1march
kishore1march
Contributor
Posted: ‎2023-04-05 03:56 AM
In response to SEStig
Dear SEStig,
Pls find the reply in blue.
Is it actually animating properly (values change when they are supposed to etc)?  - Yes they are animation property and they work if the tags were updated with required values.
Are you using located addressing or unlocated addressing to the M580? - Yes, im have %UV and located variable address as-well  in HMI variable list but iam not assigning to any animation. Plannng to delete at the end of the project.
If you are using unlocated, are you using the Data Dictionary? - No.
