Continue
  • My Subscriptions
  • Events
Trend data in Vijeo Citect SCADA
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Trend data in Vijeo Citect SCADA
olivier_vallee
olivier_vallee
39
Oncom
Oncom
6
stuartm
stuartm
2
Back to AVEVA Plant SCADA Forum
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-01 02:33 AM
16
28858
Hello everyone
How do I keep my old trend data retrievalble and accessible when I update or make modifications on my application project, since I have to do this many times whenever the plant grows up, but I lose the old trend data everytime I update the project ??
  • Smart Design & Engineering
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-01 05:50 PM . Last Modified: ‎2020-02-03 05:07 AM
In response to OsamaSalih
28818
trend.dbf also contains a column called FILENAME which is actually the path (folder) where the trend files will be stored.
If you leave this as blank, then it will place them within your Citect.ini configured Data directory (thanks @RoozeeR).
You should read up on the help for these, and configure them as appropriate so that the trend files don't get overwritten with project restores.
Help excerpt from Citect SCADA 2016
By default, Citect SCADA stores trend files in the [DATA] directory (defined by the parameter [CtEdit]Data) on the hard disk where installation occurred. However, you can use the File Name property to specify a different directory for a particular trend file.
For example, if your system includes a large number of trend tags (in excess of 1000), Citect SCADA will perform more efficiently if you distribute the associated trend files across a number of directories. To enable this, you could set the File Name property for a trend tag to the following:
[DATA]:Area1\TANK131
This would store the trend file in a subdirectory (named "Area1") within the [DATA] directory.
Replies 16
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-01 02:45 AM
28837
This is likely the case if you are storing your Trend files within a subdirectory of the Project directory.
I would advise to configure (in the trend.dbf) your Trend File locations to be outside of your Project directory.
In this way, when the project backups are restored / overwritten, the Trend Files are not touched, and when you launch the runtime again, it can find them appropriately.
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-01 07:08 AM
In response to BevanWeiss
28829
thank you sir for response
Trend. dbf contains tag names and the variable tags they connect to plus some other parameter for each tag, I can not find a parameter to be set to change the trend file locations, please advice
BevanWeiss
BevanWeiss
Champion
28818
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-02 12:15 AM
28812
Thank you sir, I accept this solution even before I try it, you are genius 😃
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-02 12:17 AM
28810
It's been working for the majority of our customers... so I've got some confidence that you'll find some guidance on it in the help 😉
The help is your friend...
RoozeeR
RoozeeR Mentor
Mentor
Posted: ‎2020-02-03 04:41 AM
28794
The DATA directory where trend files are saved is "normally" set by running the Citect SETUP wizard. In the end tis results in a setting in the Citect.INI file (CtEdit - Data parameter).
R.Roozee
Sr Solution Architect (SAE Master)
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-04 08:25 AM
28776
Hi @BevanWeiss What I found out is that DATA folder will not be overwritten when the updated backup file be restored, because it is located out side the project folder, this means that defining different folder from the default one for trend data will have no effect of the trend data exsitance, this needs more discussion to be clarified
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-04 08:29 AM
In response to RoozeeR
Hi @RoozeeR  This has no impact on the project being restored, as the data folder is located away from project folder,  maybe I am missing something, the restored project will not touch the data folder and its contents, then why data will be lost?
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-04 04:04 PM
28768
If the Trend folders are outside the Project folder, and therefore are not being changed during a project restore, then I would suspect that the person doing the project restore may be doing something else also.
Are you able to perform the following:
1) confirm location of trend files matches expectation from DATA and Trend.dbf settings
2) Shutdown Citect runtime
3) Confirm Trend files are still correct in the location expected
4) Restore project backup
5) Confirm Trend files are still correct in the location expected
6) Start Citect runtime
7) Confirm Trend files are still correct in the location expected
As Citect can run Cicode which could technically do whatever it wanted, there is the possibility that something within the Citect project is messing with the Trend files.  But I wouldn't expect this.
If you do the steps above it will narrow down where the issue is with the entire process, or where the trend files are being disrupted.
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-23 04:51 AM
28654
Hi @RoozeeR
Sorry for delayed reply
I can do the mentioned task with no problem, all files are remains in place
The plant herichary composed of two servers and two clients of which one server is duty and the other one is standby
the files count in DATA folder are not the same in the servers, as it is higher by nine files in the standby server
I do not know if that helps
Regards'
Osama
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-23 05:08 AM
28652
I don't believe historical trend files are synchronised between trend servers.
So there being a difference in the file count doesn't surprise me.
It seems that it was a user error that was causing the issue you reported in the original post.
I believe that you've now got things all sorted as you say the restore is now not deleting trend files.
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-23 11:28 PM
@BevanWeiss
Yes you are right , everything looks good now
thank you again
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-25 10:52 AM
28616
I am going to confirm if trend sychronizing happens betwedn two server or not as soon as I can,
as server 1 is the main server, I am going to switch to server 2 to be the duty server and check if historical trend exist and can be displayed
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-25 11:14 AM
28614
How will you do this test?
I'm afraid that how you think the test will work is going to produce the wrong result.
Of course if you look at trend files currently being produced it will be fine.
What you need to do is 'remove' (i.e. move elsewhere) all the old trend files from one server, and then restart it.
My expectation is that it will not actively retrieve ALL of the old trend files from the online server.
OsamaSalih
OsamaSalih
Explorer
Posted: ‎2020-02-25 12:13 PM
28612
Yes, I dont mean the test you mentioned, I only looking  if both server have almost all data by switching dutu server from one another
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-25 12:20 PM
This is precisely what I mean.
That does not test the trend server synchronisation at all.
Thato tests IO server connectivity, and that both trend servers are currently active.
You'll see here how it's supposed to work:
http://www.citect.aveva.com/webhelp/vijeo740/Content/How_CitectSCADAVijeo_Citect_handles_trends_serv...
So to test the synchronisation, you will need to remove trend files from one of the servers.
