SCADA CITECT NO ACEPTA PNG
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • SCADA CITECT NO ACEPTA PNG
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Citect SCADA
Back to AVEVA Plant SCADA Forum
Posted: ‎2020-12-01 03:44 PM
4625
Estimados colegas, saludos cordiales.
Tengo problemas con la importacion de archivos PNG, necesito importar archivos sin fondo o crear simbolos con archivos PNG. no me permite importarlos y si los importa, eston estan en blanco y negro o simplemente no se ve nada.
Alguien tuvo el mimso inconveniente? espero su ayuda por favor!
Gracias.
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Richard
Lt. Commander Richard Lt. Commander
Lt. Commander
Posted: ‎2020-12-02 06:37 AM
The easiest way to do this is to import a normal png with a plain white (or single colour) background, then use Swap Colors from the Tools menu to change the background to transparent (the selection with an x through it).
I find this is often easier than using a dedicated graphics package to set a transparent background.
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-12-02 06:23 AM
Hello @sesa222731 , Do you know who can support on this?
R.-
Rodrigo G.
Industrial Automation Community manager
Richard
Lt. Commander
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-12-02 11:18 AM
@Anonymous user You're likely to hit a wider target audience if you were to write in English (or at least use Google Translate to include an 'English' version).
In regards to wanting to have transparent (alpha channel) PNG files, this is not supported under Citect, as per:
https://www.se.com/au/en/faqs/FA27/
So you will typically have to do this in other ways.
You could probably try to get your PNG image into the Citect Graphic Builder and modify it from there to add/remove pixels as necessary.
If the background is always a consistent colour, then you could just replace your transparent sections with this colour to emulate transparency.  More difficult if the content behind is dynamic.
