A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
Posted: 2024-04-05 05:23 AM
The deployment cannot get any response to the deployment server, but it worked one week ago.
I know that this means the deployment server cannot be reached by the deployment server. This can be caused by:
But the firewalls and proxy settings have not changed and we're not on a domain, so it must be the last one - authentication surely.
So I want to ask about the detailed step of reconfiguring the deployment client using the original authentication file.
I have deleted the .config file of the Deployment client in the folder (AVEVA Plant SCADA 2023/Config) then setup again at the configurator. However, the exception message is found at the server side - Exception Message: Processing of the HTTP request resulted in an exception. Please see the HTTP response returned by the 'Response' property of this exception for details. HttpResponseException.Response:[StatusCode: 401, ReasonPhrase: 'Unauthorized', Version: 1.1.
Do anyone have any thought about this issue?
Posted: 2024-04-23 12:21 AM
Thanks, Oly, the problem is solved by synchronising the time between the server and the client.
Posted: 2024-04-21 03:07 PM
What version of Citect/Plant SCADA are you using? Can you confirm the clock time on Server/Client is the same?
Normally re-configuring the Deployment Client would resolve this issue. I'd recommend reaching out to AVEVA Customer Support to troubleshoot this further.
Posted: 2024-12-09 06:13 PM
hi
How to solved by synchronising the time between the server and the client.
Posted: 2024-12-10 04:42 PM
Hi @idersukh,
This is probably an IT question, how to synchronise time across machines.
If the machines are part of a domain, time sync is usually handled that way. There are also 3rd party solutions, which can sync your machines time. Or you can do it the old fashioned way and just adjust the time manually (they will naturally drift over a long time).
I'd recommend you google for that answer and follow what suits your needs.
