Proyect deployment with Archestra very slow distribution
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Proyect deployment with Archestra very slow distribution
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
MAJLGC
Captain MAJLGC
Captain
Posted: ‎2024-10-01 10:03 PM . Last Modified: ‎2024-10-01 10:11 PM
892
I have a Scada configuration with:
1 Scada Engineering Station as the Proyect Deployment server
2 Scada Operator Station as proyect deployment clients
2 Scada Servers (Primary and Standby) as proyect deployment clients
Proyect Deployment was OK in earliest times, but now is taking a lot of time (~ 1 Hour)
Any idea about this issue?
Thanks in advance
  • Plant SCADA Studio
olivier_vallee
Commander
Posted: ‎2024-10-02 10:09 PM
Hi @MAJLGC,
The coming October 2024 patch will have the following fix in it (plan is to release it on 8th October):
Deployment
3455908 - Deployment server performance impacted on a domain environment without an internet connection
The deployment server configuration and its operation were slow when a client used a domain controller and both the client and domain controller were not connected to the internet. The Configurator will now launch quickly under these circumstances, and the deployment server configuration and deployment operations will respond promptly.
If you require a fix before this date, I'd recommend reaching out to AVEVA Technical Support, who can guide you to implement a work around.
Kind regards
Olivier
olivier_vallee
Commander
Hi @MAJLGC,
Deployment
Kind regards
Olivier
olivier_vallee
Commander
Posted: ‎2024-10-08 02:35 PM
Hi @MAJLGC,
The October 2024 Patch is now available for download from the GCS AVEVA website.
Kind regards
Olivier
