Master Popup
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Master Popup
olivier_vallee
Lt. Commander olivier_vallee
34
Oncom
Commander Oncom
6
BevanWeiss
Spock BevanWeiss
2
RoozeeR
Lt. Commander RoozeeR Lt. Commander
2
Back to AVEVA Plant SCADA Forum
JamesBond
JamesBond
Cadet
Posted: ‎2025-09-23 07:04 PM
211
Master Popup
Hi, the first question is - I am not sure if these are standard in all plant scada installs or custom to our site?
Second question is -
I am looking at Master_Popup_HD1080.
I can see it picks up some of the information from the equipment that has been assigned to that equipment.
Though I am not finding where the information from the equipment is passed to code.
I am attempting to add a third Tab as shown and have assigned details to the below fields in the equipment as below.
Custom 1 - FP_Test - name of new Popup
Custom 2 - Test - Title of Tab (PageGetStr(x))
For the third (new) Tab
JamesBond_2-1758678606043.pngJamesBond_3-1758678623557.pngJamesBond_4-1758678643317.pngJamesBond_5-1758678654076.png
I have found a work around to achieve the overall goal. However, this method of using the Master Page > Workspace would be the better solution, if possible.
  • Equipment Editor
  • Graphics Builder
  • Plant SCADA Anywhere
  • Plant SCADA Runtime
  • Plant SCADA Studio
  • Scripting - Cicode
  • Situational Graphics
olivier_vallee
Lt. Commander
Posted: ‎2025-10-02 08:25 PM
158
Hi 007 (@JamesBond)
Hope you are serving King and Country well.
It is difficult to answer your first question, I can't get enough details about what you are referencing. I'd suggest to take a look at a fresh installation of Plant SCADA, see the default projects and include project:
System
Include
Library_Controls
Library_Equipment
SxW_Style_Include
Tab_Style_Include
SA_Include
SA_Library
SA_Controls
IndustrialGraphics_Include
Example
ExampleSA
So anything outside of this is custom for your site. Something an Engineer or System Integrator would have created or configured for your site. For example, that popup page "Master_Popup_HD1080" is not part of the default library or content in Plant SCADA.
With regards to your second question, it is difficult to make suggestions based on the screen shots and description you have made. I'd recommend taking a look at the ExampleSA project for how equipment and popups are used.
It sounds like you have got something working for your needs, but I understand you'd like to keep the coding practices and configuration consistent.
Do you still have contact with the person who originally developed the project?
Kind regards
Olivier
JamesBond
JamesBond
Cadet
Posted: ‎2025-10-19 08:15 PM
In response to olivier_vallee
Hi Olivier, sorry for the delay in getting back.
Whoever wrote this has long since gone.
Looks like only the Content field / property is actually passed to PopUp.
1st Tab
Text - PageGetStr(1)
UpCommand - WorkspaceTabSelect(WinNumber(), 0)
2nd Tab
Text - PageGetStr(2)
UpCommand - WorkspaceTabSelect(WinNumber(), 1)
The strings must be getting set somewhere.
olivier_vallee
Lt. Commander
Posted: ‎2025-10-30 05:17 PM
Hi @JamesBond
Yes, it looks like PageSetStr must be called somewhere else. It isn't done via the equipment parameters as you have seen in your last post. Maybe do a search for "PageSetStr" on the page where this popup is called. It might also be within the popup page itself.
It might be worth reaching out to AVEVA (or Schneider) Technical Support and walk through your project with them.
Kind regards
Olivier
