How to print Citect SCADA alarms automatically to printer?
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • How to print Citect SCADA alarms automatically to printer?
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
shabeenek
Crewman shabeenek
Crewman
Posted: ‎2024-08-24 02:11 AM
779
I'm using Citect SCADA 2018 R2. I have connected the SCADA pc to EPSON LQ 2190 printer. I have to configure to print alarms to the printer line by line with date and time. How?
  • Plant SCADA Runtime
olivier_vallee
Commander
Posted: ‎2024-08-26 09:59 PM
Hi @shabeenek,
This is from a very old TechNote (TN26484) so I cannot vouch for its currency or if it will work, so I am providing this as is:
"For a Device configured as Filename "LPT1.DOS" and Type "ASCII", there are two things to check;
1. There must be a Format specified for the device or NO data will be output to the printer.
For example to output a line of text up to 132 characters you may specify a format like; {text,132}
2. Try selecting the "RAW" data type from the 'Print Processor....' selection button for that printer's profile:
Windows NT uses print processors to interpret what type of data is being passed from the spooler to the graphics engine. Windows NT defines a number of data types (for example, RAW, RAW [FF Appended], RAW [FFAuto], TEXT, and NT JNL 1.000) to implement print job alterations.
Raw files need no processing from the print processor.
The NT JNL 1.000 (or NT EMF 1.003) data type indicates that the job is being sent from a Windows-based application and uses GDI commands to describe the output while the TEXT datatype indicates that the job consists of ANSI text.
A Device configured as Filename "LPT1:" and Type "Printer_Dev" will not print line by line in real time.
I hope this information helps.
Kind regards
Olivier
