Help :About AVEVA PLANT SCADA 2023 R2 DRIVER
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Help :About AVEVA PLANT SCADA 2023 R2 DRIVER
olivier_vallee
Lt. Commander olivier_vallee
34
Oncom
Commander Oncom
6
BevanWeiss
Spock BevanWeiss
2
RoozeeR
Lt. Commander RoozeeR Lt. Commander
2
Back to AVEVA Plant SCADA Forum
yuzl
Crewman yuzl
Crewman
Posted: ‎2025-04-25 08:21 PM
1064
Does AVEVA PLANT SCADA 2023 R2 have an OPC/UA SERVER DRIVER and how to use it.
  • Plant SCADA Anywhere
olivier_vallee
Lt. Commander
Posted: ‎2025-05-06 08:21 PM
In response to yuzl
1001
Hi @yuzl ,
Plant SCADA 2023 R2 does certainly have a OPCUA Server, which is part of the "AVEVA Connectivity Service" that runs on the machine. It is optional to install, so if it isn't present, you may need to run the installer to make sure it is added and installed properly.
The first step is to run Configurator, to define the port number, whether encryption is enabled or anonymous access is allowed.
See the help topic for more details:
https://docs.aveva.com/bundle/plant-scada/page/1037376.html
You'll need to copy the OPCUA Server certificate to the client machine if using encrypted communications.
Let me know how you go and if you have any specific questions.
Kind regards
Olivier
Replies 5
olivier_vallee
Lt. Commander
Posted: ‎2025-05-04 09:05 PM
1027
Hi @yuzl ,
Yes, Plant SCADA 2023 R2 does have a OPCUA Client driver. Please see the following help for more details:
https://docs.aveva.com/bundle/plant-scada/page/843695.html
It is a bit more involved in terms of setup and configuration (especially if setting up secure connection).
Kind regards
Olivier
yuzl
Crewman yuzl
Crewman
Posted: ‎2025-05-05 05:22 PM
In response to olivier_vallee
1006
Hi @olivier_vallee ,
Thank you for your response. It appears that there may be a slight inaccuracy in my original question. I am already familiar with the OPC UA Client driver. What I aim to achieve is configuring Plant SCADA 2023 R2 as an OPC UA Server, thereby enabling communication between the OPC UA Client and the server.
olivier_vallee
Lt. Commander
In response to yuzl
1002
Hi @yuzl ,
Kind regards
Olivier
yuzl
Crewman yuzl
Crewman
Posted: ‎2025-05-06 08:44 PM
980
Hi @olivier_vallee , Thank you. I have already addressed the task and successfully verified the functionality of the OPC UA Server. Additionally, could you please confirm whether the OPC Server supports hot standby? For my project, which involves a hot standby server and standalone client, should I consider implementing a hot standby mechanism at the OPC UA Client level? Kind regards Yuzl
olivier_vallee
Lt. Commander
Posted: ‎2025-05-07 04:09 PM . Last Modified: ‎2025-05-07 04:09 PM
In response to yuzl
Hi @yuzl,
The Plant SCADA OPC UA Server does not support hot standby capabilities. It is stand alone. But you can install and setup multiple OPC UA Server's in your system, each on different host machines. If your OPC UA Client supports some redundancy mechanism, and you can provide the End Point URL for each Server that is providing data, it should work well.
