CITECT SCADA Modnet driver error 12
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • CITECT SCADA Modnet driver error 12
olivier_vallee
Lt. Commander olivier_vallee
31
Oncom
Commander Oncom
6
BevanWeiss
Spock BevanWeiss
2
RoozeeR
Lt. Commander RoozeeR Lt. Commander
2
Back to AVEVA Plant SCADA Forum
OSAMAHUSSEIN
OSAMAHUSSEIN
Cadet
Posted: ‎2025-05-01 11:25 PM
495
Hi everyone
I am transferring my project to new server , everything went fine, i have many IO devices communicationg Modbus TCP and OPC DA, all IO devices are responding successfully except one Modnet device,
When checking Tagdebug i get the following response (check attached photo)
I created a small project containing only one tag read from that IO device and it worked fine i was able to get the value of thae tag
any idea?
  • Plant SCADA Studio
olivier_vallee
Lt. Commander
Posted: ‎2025-05-05 09:15 PM
Hi @OSAMAHUSSEIN,
I think it is best to reach out to Technical Support and troubleshoot this issue further.
It looks like from the screen shot you are experiencing driver error 12, which from the help is:
Too many commands have been sent to the driver.
I'm not sure what would cause this.
It might be worth checking what version of MODNET driver you are running and if there is a newer version. From the GCS > Communications Hub, there is Modnet version 3.3.1.0 available.
I can't see any change or bug fix in the latest driver related to tag arrays.
You could also try experiment with the MaxOutstanding and MaxPending Parameters in the Modnet driver to see if this helps.
Kind regards
Olivier
OSAMAHUSSEIN
OSAMAHUSSEIN
Cadet
Posted: ‎2025-05-05 09:39 PM
Thanks you Olivier for support
olivier_vallee
Lt. Commander
Posted: ‎2025-05-06 08:29 PM
Hi @OSAMAHUSSEIN ,
I recommend posting your other question that you sent me, on the public facing forum.
It is probably not something I can assist you with, as it is in the realms of technical support. I recommend reaching out to your local Technical Support channel and get further assistance from them (with the Web Client Deployment Issue you mentioned).
There might also be an issue with replying to DMs in the forum, since I can't reply to any messages at the moment.
Kind regards
Olivier
