#BAD tag issue with N interger tag of a SLC500
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • #BAD tag issue with N interger tag of a SLC500
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
ryanhuynh
Ensign ryanhuynh
Ensign
Posted: ‎2025-08-03 11:49 PM
239
Hi all,
As title described, I have issue with one integer N7:43 tags from a SLC500. Others tag from this plc is working fine such as F8:... Only tags that start with the N is not working.
FIN_TFA / FIN_TFA_CUPWT_TARGET/ INT / FIN_TFA_PLC/ N7:43/ 0/ 5000/ FIN_CLUSTER /a8a99410-4c65-485d-a1f5-ae51d4ba6e6d
here is my variable config.
Any ideas?
Br,
  • Plant SCADA Studio
olivier_vallee
Commander
Posted: ‎2025-08-17 04:38 PM
Hi @ryanhuynh
Can you confirm some details for me...
What version of Plant SCADA / Citect are you using?
What driver are you using? What is the version of the driver?
You could try the following:
- Download latest driver from AVEVA Global Support website: https://softwaresupportsp.aveva.com/en-US/downloads/drivers/list
- Create a new empty test project, then define just this PLC and a single variable tag (the one you are having trouble with). Does the value display correctly? If not, enable driver logging to see what error is being reported.
Kind regards
Olivier
