Aveva Plant Scada 2023 R2 read tag with symbolic address from GE 90-30 PLC using GETCP driver
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Aveva Plant Scada 2023 R2 read tag with symbolic address from GE 90-30 PLC using GETCP driver
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
job517
Crewman job517
Crewman
Posted: ‎2025-08-04 12:41 PM
599
Hi everyone, I m working on a project that includes General electric plc and aveva plant scada . The versions are as follow:
Aveva Plant Scada 2023 R2 v8.50
General Electric PACSystems RX3i / CPU type IC695CPU310 / using Ethernet module IC695ETM001
Protocol is TCP using GETCP driver
I downloaded the GETCP driver since it was not included in the plant scada installation.
When I open the "Driver reference help" I can see the address format for reading various variable on the PLC(see attachedd image)
Since there is no mention of Symbolic addressing I doubt plant scada can read symbolic addresses from the GE plc. I have no means of testing this. In the meantime I just use the tagname /variable name  in the address colomn in plant scada . not sure if it will work.
Has anyone tried using symbolic address between Aveva plant scada and GE Fanuc PLC using the GETCP driver?
Thank you for your assistance
  • Plant SCADA Studio
  • driver
  • GETCPdriver
  • PlantSCADAdriver
  • SymbolicAddressing
olivier_vallee
Commander
Posted: ‎2025-08-10 05:57 PM
Hi @job517
The GETCP driver does not support symbolic addressing.
As @sinced mentioned, the best approach would be to use a 3rd Party OPC Server (DA or UA) then use the Plant SCADA OPC (DA or UA) driver.
Kind regards
Olivier
sinced
Ensign sinced
Ensign
Posted: ‎2025-08-05 08:03 AM
1
591
Use an OPC Server if you want to use symbolic addresses.
olivier_vallee
Commander
Hi @job517
Kind regards
Olivier
job517
Crewman job517
Crewman
Posted: ‎2025-08-12 04:48 AM
In response to sinced
Thank You @sinced  I ended up with more than a 1000 errors when writing tag names under the address colomn .
Clearly the Driver does not support symbolic Addressing. OPC is the way to go
