Aveva Plant SCADA 2020 R2 compile project doesn't work
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
Send InviteCancel
Posted: 2022-09-2602:44 AM
I create a project E. process expert and I tried to open this project in Aveva Plant SCADA 2020 R2 which is installed together with E. process expert. I restored all necessary projects (including project)which I downloaded from E. Process Expert but I could not compile the project and the setup wizard could not be opened. Also, I tried to restore the project which is the Citect SCADA 2016 version but it could not compile, etc. but I can see pages and other settings.
