AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
UdayShah
Ensign Ensign
Ensign
Availability of the “EcoStruxure Machine SCADA Expert – Asset Link” - Integrate Modicon controllers with EMSE
  • EcoStruxure Machine SCADA Expert – Asset Link is a Software Integration tool to engineer Integrated Automation Systems using EcoStruxure Machine SCADA Expert (EMSE) and Modicon controllers – Process Automation Controllers (PAC) and Machine Controller.
    Asset Link will
    Create: New objects in EMSE if the asset has been added to the controller
    Re-Create: Replace objects in EMSE based on a new template if they are changed in the controller
    Update: Update attributes of the asset for communication, descriptions and initial values to match the controller
    Remove: Identify (but not remove) objects from EMSE when they no longer exist in the controller
    For New projects Ecostruxure Machine SCADA Expert - Asset Link should be considered once the standard objects have been validated. Using the approved objects to generate the rules Asset Link will ensure that assets are automatically created and updated based on the control. Linking to the controller ensures comments and values are only entered once resulting the a high level of configuration quality.
    For Existing sites Ecostruxure Machine SCADA Expert - Asset Link it can be applied at anytime. The site needs to identify a single asset of each type to act as their master to generate the rules. The same rules can then be validated across the entire configuration to identify inconstancies in configuration.
    A site with a high quality of configuration will be easier to maintain, diagnose and upgrade. This will save the end-user time and effort across the life-time of their control system. A site which ensures a single point of configuration for configuration will faster to modify and always provide the operator with accurate information.
    Ecostruxure Machine SCADA Expert - Asset Link offers strong value to any Modicon + EcoStruxure Machine SCADA Expert Customer.
    You can download it from this link : https://schneider-electric.box.com/s/a3l0j8xlkomqhyk5g5kqmk8dh8sku79s
Replies 0
