unpack/ intial setup procedure APC SMT1500IC
Select a Country
  • unpack/ intial setup procedure APC SMT1500IC
BillP Leader
2150
144
Techie_apc
Techie_apc
83
a-new-SMT1500IC-in-2024
Explorer
Posted: ‎2024-12-31 04:56 AM
914
is this the optimal setup procedure for a new SMT1500IC?
  1. unpack the device,
  2. inital connect battery + device
  3. connect power cable to apc
  4. press power-on button 1-2 seconds
  5. intial display wizward should appear (date, language etc)
  6. check if network-card is reachable via https
  7. connect server, switch, etc. to the APC
  8. wait a couple of hours
  9. do a runtime calibration
  10. check if battery install date is up2date at the webui
  11. READY
next step:
automatic shutdown procedure configuration
intial recommened steps in webui of the network card:
time-zone, ntp, dns, static-ip, alert-email
TBC
  • Home & Office - UPS & Software
Champion
Posted: ‎2025-01-02 03:49 AM
All look good but some clarification as it relates to the battery calibration. This procedure requires a minimum of 30% attached load connected to the outputs.
This procedure is very tough on the battery cartridge. As the cells are rated to endure 260 full depletion cycles from new.
As such a battery calibration should only be done once a year or when a new cartridge / cells are installed to obtain the most accurate (displayed) operational runtime on the system.
Ensure you update the energy / CO2 costs in the NMC. If your system has the option to enable / disable Green Mode leave it on.
Event / Data logs: Change the retention value from 1500 / 30000. 1500 for NMC 2 cards and 30000 for NMC 3 cards. If the system has a NMC 3 card change the interval from 10 to 5 minutes.
Power Settings: Leave the sensitivity in normal mode.
Output Voltage: Adjust both upper and lower voltage transfer to 127 / 106 VAC.
Questions Ask . . . 👍
Champion
