" power sys error -02000 " in APC UPS SRT5KLXI
  • " power sys error -02000 " in APC UPS SRT5KLXI
2150
127
Posted: ‎2021-06-28 04:53 AM . Last Modified: ‎2024-03-27 01:24 AM
10368
When the UPS SRT5KLXI firs came and put into operation for the first time, the LCD screen turn in to red an show me "Battery Sys Error 0800". I follow the Troubleshooting and update the firmware to the version 4.1.1. Then there was no problem until now.
My SRT5KLXI UPS has suddenly reported " power sys error -02000 " and the output voltage goes down.
The first thing i do was brain dead the UPS by removing its input, then i turn off the UPS Output from the display under Control menu and remove the batteries. Then pressing the On/Off button of the UPS i select Internal Power Off. This steps i found in this forum came in to nothing and the problem still there and I can't find any information about what to do.
How can i solve this problem ? has the ups hardware fault or it's software fault ?
thank you .
  • 02000
  • error
  • power
  • srt5klxi
  • sys
  • ups
Experienced same problem this morning. Would be glad to have a feedback when the solution is found.
Estimado, buenos dias. Recuerda la soluciòn al error , POWER SYS ERROR 02000? tengo ese problema hoy con una APC RT 6XKLI.-
SALUDOS
SALUDOS
Hi Edgardo Could you contact your local Customer Care Team ( +08104447246) about this issue and they will look after you Regards Matt
