can't get the ups automatically turned on
  • can't get the ups automatically turned on
2150
125
Posted: ‎2021-06-28 08:47 PM . Last Modified: ‎2024-03-26 01:01 AM
799
hi,
i can't get the ups automatically turned on again after battries lose all its back up power. thats why i have to manaully turn it on sometimes.
is there any option that makes the ups restart automatically when the power back on?
Model: back-UPS CS 650
regards,
Ammar
Are you using any APC PowerChute softwares at all? I believe that this units will need to be turned on manually after a battery discharge. The reason behind that is that if say another power outage occured after it has done a complete discharge, and the batteries were still low, it may not support your load and drop it.
Smart-UPS will allow you to tweak settings so that the UPS powers up after the battery has reached a capacity, or immediately.
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
Do you mean when the batteries do a full discharge, causing the UPS to completely turn off (as opposed to Low Voltage Sleep Mode )? If that is the case, because the batteries are fully discharged in a Back-UPS, you would have to physically turn them back on.
Hello, and thanks for prompt replay
"Do you mean when the batteries do a full discharge, causing the UPS to completely turn off "
yes, this is exactly what i meant. I want the ups to be turned on again automatically when the power back. is this possible? i don't want to manaully turn it on.
thanks
Ammar
