Continue
  • My Subscriptions
  • Events
back-ups es 750 constant beep
  • back-ups es 750 constant beep
BillP Leader
2151
156
83
Posted: ‎2021-07-11 10:57 PM . Last Modified: ‎2024-03-19 11:44 PM
11898
I have a back-ups es 750 that just started making a constant beep with a red light that looks like 2 batteries. I turned it off and on and it gave a long beep and then started constantly beeping again. Does the battery need to be replaced? How do I order one and what is the cost?
  • beeping
BillP Leader
Leader
Is the unit beeping every second or is there a constant tone? If the unit is beeping every second that indicates low battery but the beeping should stop when AC is available and the battery should charge. If there is a constant tone that indicates the battery in disconnected, needs to be charged, or is at the end o f useable life. Section 3 of the user’s guide lists the status indicators i.e. what each alarm means.
User's Guide http://www.apcmedia.com/salestools/KBOK-766PMZ/KBOK-766PMZ_R2_EN.pdf?sdirect=true
BillP Leader
Leader
