Posted: 2021-06-29 07:30 PM . Last Modified: 2024-03-21 02:53 AM
Hi, i've just bought 2 battery replacement, and when they cames to me i realize i've bought wrong one.
i've 10 Backups ES400 (BE400-IT) and i've to change battery. I thought this one (link below) was good but it more bigger in width. i've tried to plug in equally, it starts work but after 5 minutes going in blackout.
http://www.e-key.it/prod-apc-battery-cartridge-replacement-20121.htm
could someone give me a model number o something else to find the right battery?
thanks
Message was edited by: SerPiolo
is it good for this one?
APC BE700G-IT 700VA
http://www.eprice.it/ups-per-desktop-pc-APC/d-2359641?meta=TRVP&utm_source=TRVP&utm_term=Back-UPS+ES...
Technically the correct battery is apcrbc106. Other batteries may fit and connect but may not work properly. We can only guarantee our batteries(and the correct battery) will work with it.
thanks. i'll ask for a replacement...
unfortunatly shop won't replace the battery.
so i've to bought one that use this kind of replacement.
SUPPLIER PART NO. RBC17
PRODUCT SERIAL NO. 7A1229L14847
12V / 9Ah
UPC CODE 731304206811
Dimension: 150x94x62 mm
i've an HP Proliant ML110 G6.
could someone suggest me an ups tower that use my wrong replacement? so i will use it in the future...
thanks
PS. i'd like to spend between 100-200€
APC BE700G-IT 700VA
