Posted: 2021-06-28 06:30 AM . Last Modified: 2024-03-27 12:03 AM
My battery backup and surge protector's plug has three prongs but my wall out has two. Can I use an adapter to convert the plug to three?
Also I have two power strips with about 12 plugs on each, can I plug each of those strips into a plug on the APC unit?
On 10/10/2017 9:10 AM, JD said:My battery backup and surge protector's plug has three prongs but my wall out has two. Can I use an adapter to convert the plug to three?
You should not. The units are designed with the ground to allow the unit to pass excess energy to ground in the event of a surge. Also, you will void any warranty and in most cases you will violate local electric code.
On 10/10/2017 9:10 AM, JD said:Also I have two power strips with about 12 plugs on each, can I plug each of those strips into a plug on the APC unit?
Again, you should not. You could possible overload the UPS or surge unit/s and again will void warranty and possible violate electric code.
You should ask a local electrician to swap the outlet for an approved grounded outlet.
