Posted: 2021-06-29 10:41 PM . Last Modified: 2024-03-20 01:08 AM
So I have a UTS6H that had been sitting in the box for going on 2 years now.. I finally got around to installing it and have a few questions.
I wired up the 6 circuits as follows:
1) Computer Room (This is a 42U Rack w/ some servers and a 3000VA UPS) (20 AMP Circuit)
2) Kitchen/Fridge (Fridge and 1 Outlet that powers the Toaster) (Not sure on AMP Rating, have to look again)
3) Living Room Outlets/TV (15 AMP Circuit)
4) Main Floor Lights (15 AMP Circuit)
5) Kitchen Outlets (?? Amp Circuit, need to re-verify)
6) Basement & 2nd Floor Lights (15 AMP Circuit)
Backup 1 is wired with a 10/3 whip to a Yamaha EF2800i (Manual start). Planning on replacing this with a UTS10BI and a Yamaha EF6300iSDE in the future so I can provide power to more circuits.
I also have a 3000VA UPS which I plan on plugging into the UPS outlet (I am also setting this up with extended run batteries. Although it is a 3000VA normally wired to a 20AMP twist lock, I re-wired it as a 15AMP plug so it will provide longer run time with the lower load of the 15AMP maximum)
The question I have is how I should wire up a few different things. Specifically the UPS, and some questions around Circuit 1 - questions below.
1) Where should I plug the UPS in? Just any random outlet that will lose power during a power outage - or should this be plugged into a outlet that is powered by the generator/ATS during an outage? (So that it will recharge during the outage)
2) I noticed that in the Operations Manual on Page 11 it states: "Note: Backup power source availability varies for some circuits - The UPS and EITHER backup power source options are not available for: Circuit 1 on all units and the designated 240V circuits on the UTS6BI or the UTS10BI." Why is Circuit 1 unavailable for UPS or EITHER? Is it available for Uninterruptible? I wanted this circuit to be powered by UPS until I can fire up my generator.
Posted: 2021-06-29 10:42 PM . Last Modified: 2024-03-20 01:08 AM
One last question..
I currently have the UTS6H wired to my YG2800i via the L5-30 connection. What is the maximum generator size the UTS6H can support when wired utilizing the L5-30 plug? How many watts cabled this way vs hard wired?
hello,
i have got some feedback for you on this.
That makes sense.. Okay so Circuit 1 can be powered by Backup Source 1 - Generator.. That should be fine then since I already have a UPS on Circuit 1 (It is a rack of computer equipment). It should be fine until I start a generator manually.
Much appreciated on the quick response. Now it makes sense on why circuit 1 is not usable in that setup.
you're welcome
One last question..
