UTS10BI 240V AC load
  • UTS10BI 240V AC load
2151
119
Posted: ‎2021-06-29 10:42 PM . Last Modified: ‎2024-03-20 01:07 AM
714
I have UTS10BI switch installed with 2T AC (1/6 HP) unit (15AMP min and 25 max) connected to 220 circut(9/10). My generator Honda EM6500. When AC starts switch shows overload on circuit 9 ad disconnects the load, so my AC never starts. Is there any settings I can change to support AC?
  • Universal Transfer Switch
Once I change fuse how can I change circuit settings on the unit to 20 AMP?
Thanks in advance for any help
http://www.apcmedia.com/salestools/ASTE-6Z7VBL_R1_EN.pdf
check PDF page 12-13. it will outline how to get to the circuit configuration.
you might want to try a 20A fuse for that circuit if you haven't already which i believe also will require you to adjust the circuit setting on the unit itself to 20A as well. by default, each circuit has a 15A fuse.
