USB Cable 940-0127E vs 940-0127A/B
  • USB Cable 940-0127E vs 940-0127A/B
2151
123
Posted: ‎2021-06-29 10:07 PM . Last Modified: ‎2024-03-20 03:16 AM
8040
Dear APC Team,
I have couple of questions regarding the cable 940-0127E FCI.
1. Is that simple or smart cable?
2. What is the difference between 940-0127E and 940-0127A/B cable?
3. What means FCI at the end of the P/N?
4. Is that a pure USB cabe or it's RS232 cable with USB connector?
I'm using UPS BR550GI.
I'm looking forward to hearing from you!
Sincerely Yours,
Nikolay Zhelev
What I know is:
  • Some places reference this as a simple cable but I think it has both simple/smart applications. For this UPS, it is a smart cable/communication - meaning two way communication between UPS and the computer (or whatever you connect it to). Simple is what we call a one way communication cable - from the UPS to something else. This application is smart in the sense you can issue commands, read information, change settings, etc.
  • We change the letter on the cables to identify the revision. When we change it, it is usually because we changed a connector, vendor we use, color, etc. If the part number remains the same, then it has the same functionality.
  • FCI is the vendor that makes the cables. As a general strategy, many of our parts/cables are sourced from more than one vendor and we ensure the functionality remains the same, in case there is a problem sourcing parts from a single vendor.
  • This is a standard USB cable with a keyed RJ-45 connection
Hi Angela,
Thank you very much for this complete answer!
Kind Regards,
Nikolay Zhelev
What I know is:
Hi Angela,
Kind Regards,
Nikolay Zhelev
