UPSCAPO only logs for a few hours
Showing results forΒ
Did you mean:Β
  • UPSCAPO only logs for a few hours
2151
Spock Teken
83
Unreal12
Crewman Unreal12
Crewman
Posted: β€Ž2025-04-18 12:10 AM . Last Modified: β€Ž2025-04-18 12:33 AM
1826
Hello, I have an APC Easy UPS SMV SMV1500CAI and would like to generate log files.
According to Schneider, it's not possible to install a network management board in the UPS, and I was recommended the "UPSCAPO" software.
Everything works fine, but the log files suddenly stop a few hours after starting the software.
UPSCAPO continues to run, and no errors are visible.
Only, no logs are being written.
Do you know this phenomenon? I use Server 2022.
Thanks and regards Unreal
edit: The Logs stopped at 2025.04.17 22:54:40, although I didn't do anything
  • Home & Office - UPS & Software
Replies 10
Spock Teken
Spock
Posted: β€Ž2025-04-18 04:23 AM
Change the interval to every 60 seconds and report back the results. Lastly, insure all power save / energy management is disabled on the USB port. ☝️
Questions Ask . . .
Unreal12
Crewman Unreal12
Crewman
Posted: β€Ž2025-04-18 11:28 PM
1419
Hi, Thank you very much! Unfortunately, this hasn't worked yet. After changing the settings, the log ran from: 7:52 PM to 10:31 PM = 2 hours, 39 minutes Before (old settings): 8:25 PM to 10:54 PM = 2 hours, 39 minutes So exactly the same length. The only USB power saving settings I found in Windows were the following (sorry, screenshot in German): "Setting for selective USB power saving." I've now disabled this when plugged in. As I said: Unfortunately, to no avail 😞 Best regards
Unreal12
Crewman Unreal12
Crewman
Posted: β€Ž2025-04-21 10:45 AM
Hi, I've been testing a few things again. What did make an improvement was running the UPSCAPO service under a different account (as a domain admin for testing purposes). It's been running smoothly for 8 hours now. By the way, I'm currently using version 3.2.5 because it's still available on the APC website. I've also found a version 3.2.6. However, I'm not sure if you can still leave the power saving settings to Windows, or if UPSCAPO is forced to do it in this version... Regards, Unreal
Unreal12
Crewman Unreal12
Crewman
Posted: β€Ž2025-04-21 12:40 PM . Last Modified: β€Ž2025-04-21 10:54 PM
Update: After a few (many) hours, it crashed again. Maybe I'll try version 3.2.6.
Spock Teken
Spock
Posted: β€Ž2025-04-22 02:59 AM
In response to Unreal12
1411
Please disable (ALL) power saving / energy star settings on this system as a validation test.
If the system is set to Suspend, Hibernate, Sleep, turn this off too. Report back the results after doing so along with replacing the USB Data Cable.
Questions Ask . . . πŸ‘
Unreal12
Crewman Unreal12
Crewman
Posted: β€Ž2025-04-22 05:04 AM
In response to Teken
1394
Hi! I'll take a look at everything. The server is a Hyper-V host, though. I can't simply reboot or anything like that. I'll check Control Panel/Energy Settings again to see if I can disable anything there, and I'll try changing the cable.
Spock Teken
Spock
Posted: β€Ž2025-04-23 04:25 AM
1390
I suggest you install the same software on a bare metal machine and see what the results are and report back the same.
You may very well see the problem only exists in the VM system.
Unreal12
Crewman Unreal12
Crewman
Posted: β€Ž2025-04-23 05:12 AM
Hi!
This is not a VM.
Its a Hyper-V Host.
Bestreg
Unreal12
Crewman Unreal12
Crewman
Posted: β€Ž2025-04-24 09:05 AM
Hi!
It is possible to connect the USV via RS232?
What cable do i need?
Bestreg
JamiePhillips
JamiePhillips
Cadet
Posted: β€Ž2025-10-09 10:03 PM
I have been having the exact same issue for about the past 2 years.  Tried contacting support who were able to replicate the issue but came back with no solution was available.  My configuration is exactly the same as Unreal12 with same symptoms.  I wish we could use Powerchute Business Edition which is why I always used to purchase APC units but not any more.
Β
