UPS Charging Even When Turned Off?
  • UPS Charging Even When Turned Off?
2150
127
Posted: ‎2021-06-28 09:16 PM . Last Modified: ‎2024-03-26 12:41 AM
7686
Does the batteries inside the UPS continue to charge (after UPS has gone into battery mode) even if it is turned off but is connected or plugged into the AC source? Or does charging only happens if the UPS is turned on?
Message was edited by: yanaice13
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
I beleive it depends on the type of UPS. Some of them do charge when not powered on, some do not. Any particular model in mind that we can take a look at for you?
Say for the ES, CS and RS back-ups series....and the smart ups as well 3KVA below.
EZ_Button_apc
Commander EZ_Button_apc
Commander
As soon as AC power is sufficient the batteries will charge regardless of if it powered off or on.
I'm not aware of any UPS where the charger circuit is downstream of the power switch. For the most part, you can assume as long as its plugged in, it will continue to charge.
Where do I find this "sufficient" AC power? Is it in the spec?
Thanks,E
Please advice..(1) i use an APC UPS and i noticed suddenly that after sometime my generator cant power it whenever i powered it, it use to work with the generator before but not anymore.... I assume the battery is down... what do i need to do?
(2) Will the battery charge with direct AC source while the UPS is turned off ? i need to know
7687
Yes. The UPS will charge when powered off when connected to AC source.
Have you tried to adjust the sensitivity of the UPS? See Knowledge base document FA156514 for assistance.
Replies 9
TheNotoriousKMP_apc
Sisko
EZ_Button_apc
Commander
Thanks,E
thanks
7688
JMKAUTO
JMKAUTO
Cadet
Posted: ‎2024-03-07 03:06 PM
In response to BillP
You generator probably producing dirty electricity or incorrect hertz.
