UPS BH500|NET username and password problem
  • UPS BH500|NET username and password problem
2150
127
Posted: ‎2021-06-29 07:42 AM . Last Modified: ‎2024-03-21 04:44 AM
1655
I have problem with username and password on device. I have UPS BH500|NET and i can`t login to the device after change username and password. If I use reset button, config device will change to the default settings, but username and password NO. apc/apc not worked. Can You help me?
Type: APC Back-UPS HS 500
Serial number: AB1130849449
Firmware revision: l1
Web firmware revision: l5
Thank You very much, regards Lukas.
@krislukas PM sent with backdoor usr and password info
Replies 6
michalkolar  Please send me a direct message and I'll send you a password.
  • apc
  • management
Please refer to this thread -> Re: bh500net APC Back-UPS HS 500 username and password problem
I pressed reset button on my APC Back-UPS BH500|NET, but default username and password don't approach.  Please help me.
s/n: 3B1025X22630
Thank You very much.
Hey there,
I got the same problem with a APC Back-UPS HS 500. I changed my password several times before, but this time I also used symbols. I think this is the point where the firmware gets the problem. Anyway, could you help me the same way as the other ones here?
Technical Parameters
Model: APC Back-UPS HS 500
Serial number: AB1010844101
Thanks a lot!
