Share Your Feedback โ€“ Help Us Improve Search on Community!
Smart-UPS 500 (SCL500RM1UNC) no power on switched outlet groups
Showing results forย
Did you mean:ย
  • Smart-UPS 500 (SCL500RM1UNC) no power on switched outlet groups
2150
127
APC EASY UPS BV 500VA, AVR, Universal Outlet, 230V
Fred.
Crewman Fred.
Crewman
Posted: โ€Ž2022-01-08 10:48 AM
4250
I have a new Smart-UPS 500 (SCL500RM1UNC) and I'm unable to get power on
Group 1: Outlet Group 1 On
Group 2: Outlet Group 2 On
They are both switched on and there is no power on the outlets. Same when I switch them off.
The battery is fully charged and the UPS is in normal state and connected to the grid.
With my other UPS'es (other models) this works perfect.
The unswitched group has power and works perfect.
Main: Unswitched Group On
Is this normal? I'm trying to find out if this one is defective or if I'm missing something.
Kind Regards
Fred.
  • Home & Office - UPS & Software
Replies 9
Posted: โ€Ž2022-01-12 01:04 PM
4226
@Fred.
If the outlets show that they are on and no AC is available you should contact local Schneider Electric  technical support for assistance.
Local support contact information will be found at this link.
https://www.apc.com/us/en/support/contact-us/index.jsp
You may need to change the region in the upper left of the contact us web page.
Fred.
Crewman Fred.
Crewman
Posted: โ€Ž2022-01-13 02:21 AM
In response to BillP
4223
Hi Bill,
Thanks for your reply.
I contacted support and I have done that before with another issue but I usually get no reply or sometimes months later...
APC Support really sucks here that's why I tried it here.
Kind Regards
Fred.
Posted: โ€Ž2022-01-14 10:02 AM
In response to Fred.
4212
@Fred.
I am sorry you are experiencing this inconvenience.
  1. Have you verified the battery is connected correctly?
  2. Is the unit connected to the local network, and if so, does the network card report the UPS on and output on?
  3. Is the UPS connected to the SmartConnect portal, has it been registered, and what is the product ID?
Fred.
Crewman Fred.
Crewman
Posted: โ€Ž2022-01-15 01:17 PM
4198
Hi Bill,
See the inline reply
Yes, Visually checked it and it reports healthy.
Battery Status
State of Charge
100.0 %
Battery Voltage
15.7  VDC
Health
 OK
UPS Input
Input Voltage
228.1  VAC @  50.0  Hz
Yes
UPS Output
Output Voltage
229.9  VAC @  50.0  Hz
Load Current
0.0  Amps
Output VA
0.0 %
Output Watts
0.0 %
Output Energy Usage
17.38 kWh
Outlet Group Status
Group State
Only the unswitched group has power.
No it's not connected to the smartportal and not registered.
About UPS
Model
Smart-UPS 500
SKU
SCL500RM1UNC
Serial Number
5S2112T52850
Firmware Revision
UPS 02.5 (ID1029)
Manufacture Date
03/28/2021
Apparent Power Rating
500  VA
Real Power Rating
400  W
Battery SKU
APCRBC167-LI
Fred.
Crewman Fred.
Crewman
Posted: โ€Ž2022-01-18 12:46 AM
I called support again today and was promised they are going to take up the case.
Let's see if I hear something back from them in the next days.
Posted: โ€Ž2022-01-18 12:41 PM
4165
The SCL5000RM1UNC is designed for
Input frequency
47 - 63 Hz
Input voltage range for main operations
92 - 139V
If your input voltage is 228.1 the UPS will not work. If you are located in an area the normal AC is 50 Hz, 230V you should be using a SCL500RMi1UNC
https://www.se.com/ww/en/product/SCL500RMI1UNC/apc-smartups-c-lithium-ion-short-depth-500va-230v-wit...
Fred.
Crewman Fred.
Crewman
Posted: โ€Ž2022-01-19 01:41 AM
4161
Hi Bill,
It's a SCL500RMi1UNC. But there is something wrong with it.
I send them logs and screenshots.
They agreed to swap it.
Just waiting to hear when they want to do the swap now.
Fred.
Crewman Fred.
Crewman
Posted: โ€Ž2022-01-19 01:52 AM
I see what's going on now.
The box and the back of the device says it's a SCL500RMi1UNC but the SKU says SCL500RM1UNC
I guess this device was made on a Monday morning ๐Ÿ˜›
Also the Quality Assurance test is not signed. but passed. And it reports SCL500RMi1UNC
Fred.
Crewman Fred.
Crewman
Posted: โ€Ž2022-02-01 09:31 AM
I received a new UPS today same model but this one is working perfectly.
Thanks everyone ๐Ÿ™‚
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
