APC BX1500G Powerchute reporting issue with battery
  • APC BX1500G Powerchute reporting issue with battery
2150
127
Posted: ‎2022-02-01 07:19 PM
850
I have just replaced my battery in my APC BX1500G. The new battery was tested in 2021 as per the note left with the new battery. When I run a self-test on the unit the app is reporting that my new battery did not pass a self-test, the battery in the unit need to be replace. The battery is brand new.
Anything that I can do to fix this false error?
Thanks in advance
Luc
  • Home & Office - UPS & Software
Posted: ‎2022-02-02 09:48 AM
843
@Anonymous user
Open the PowerChute UI and change the battery replacement date. Then run a self-test.
If that does not resolve the issue you should run a calibration.
  • Stop the Power Chute software from running and disconnect the USB cable.
  • There must be at least a 30% load attached to the UPS during this procedure, and this load cannot fluctuate more than +/- 5%. THIS IS IMPORTANT
  • Attach a non-critical load to the UPS and then force the UPS on battery by disconnecting it from utility power
  • Allow the unit to run on battery until it turns off completely. The load attached to the UPS will drop.
  • If the Load is not at least 30% or if the calibration is ended before the UPS drops the load, the calibration will not work.
  • Plug the UPS back into the wall outlet and allow it to recharge (preferably turned off)
Posted: ‎2022-02-03 05:20 PM
In response to BillP
thanks BillP, your instructions fixed the issue. More specific the calibration was the fix.
844
@Anonymous user
