Smart UPS 1500 shown as Smart UPS 1400XL in Power Chute
Showing results forΒ
Did you mean:Β
  • Smart UPS 1500 shown as Smart UPS 1400XL in Power Chute
2151
119
Posted: β€Ž2021-06-29 02:29 AM . Last Modified: β€Ž2024-03-22 02:30 AM
2821
Hi all,
I Have Smart Ups 1500 (as Mention on the front of ups) But Power Chute show it as 1400XL on summer Page. And it Does not have USB Connection at the
back of UPS only Rs232 Connection available. Need Help to understand what UPS actually I Have.
I Also Have Smart UPS 1000 it Correctly read by Power Chute as Smart UPS 1000 also have USB Connection at the Back
Posted: β€Ž2021-06-29 02:30 AM . Last Modified: β€Ž2024-03-22 02:30 AM
did you change the sensitivity to low already? are you able to access the unit via software/network management card to confirm the firmware versions on the UPS itself?
Replies 15
The only way to know for sure what unit you have is by checking the model number printed on the small white sticker on the rear of the unit. The bezel isn't always accurate, especially since sometimes people swap bezels around.
SUA1500I written on the back sticker
That's the UPS you have then. πŸ™‚ If that's all you wanted then you're set!
Though if you're trying to get PCBE to display the model correctly... Let's take a look at some more info.
Does the serial # displayed in PCBE match the serial below the model number you obtained?
Uou seem to be running an outdated version of PCBE (7.0.5). The current version is 8.0.1, so an update may be in order. Also, verify you're using the correct serial cable - what's the model number on the cable?
Yes the serial number are same on the sticker at the back - in power chute and litkit came with the ups. and ups is connected to the PC through cable came with the
package and i am using ver 8 of software
Per the screenshot you provided, you are using agent version 7.0.5.108. Please uninstall the PCBE agent, console, and server from Add/Remove Programs and download the latest version of the software here.
Here is the Screen with Software Ver 8
Techie_apc
Sisko Techie_apc
Sisko
Hi Mujeeb,
I notice that this unit is 7 years old according to the serial number. How long have you been using this unit? Did you repair the unit?
My suspicious is that the original circuit board might have been replaced with the Smart UPS 1400 XL UPS circuit board.
Hi all,
I Bought it couple of days ago from a refurbish store the unit is working excellent batteries charged fully except it shows as 1400 XL.
Techie_apc
Sisko Techie_apc
Sisko
oh ok..as i said, the circuit board of the unit might have been replaced by the refurbish personal. You do not need to worry if the unit is working normally since the unit is refurbished.
Sorry Folks Need help with same UPS I own SUA1000I i set sensitivity to medium works fine with generator power.
But this one (1500 or 1400 whatever it is) not working with generator sensitivity set to medium or low in power chute
keep on ticking between battery and electricity
its ok it mean that its not SUA1500I its 1400XL where can i find specs for 1400XL. and Thanks
Techie_apc
Sisko Techie_apc
Sisko
The UPS will transfer to battery mode whenever the input power is not within acceptable range in order to protect the connected equipment. For your information, Generators are not rated or designed to handle non-linear loads such as computer equipment or other electronic equipment. Using non-linear loads with a smaller generator will result in the output waveform of the generator to be much distorted. This distortion combined with variance in the frequency of the output power will most likely result in the UPS constantly operating On-Battery or frequently transferring back and forth from On-Line to On-Battery. To prevent voltage distortion and complications with a UPS, the generator must be selected so that it will supply the peak current required by the computer load, not only the average current. It has been determined experimentally that this typically requires that the generator have a rating at least 2 to 3 times the rating of the entire load to be connected to the generator. However, due to wide differences in output impedance for generators, it is not possible to specify an over sizing factor that guarantees compatibility with all systems. You may need to check the Generator to see if the output waveform is not distorted too much. Consult the Generator company for their opinions.
I have Two Smart UPS 1400XL, one is getting to charge on generator while other is not getting to charge, is there any settings required????
Please Help....
Β
