Continue
  • My Subscriptions
  • Events
Signal 2 NAS's from an APC Back-UPS CS 350 UPS
  • Signal 2 NAS's from an APC Back-UPS CS 350 UPS
BillP Leader
2151
154
Techie_apc
Techie_apc
83
Posted: ‎2021-06-29 07:03 AM . Last Modified: ‎2024-03-21 05:11 AM
2778
I have just added a new QNAP NAS to my system in parallel to an existing QNAP NAS, there is only one USB signalling port on the UPS, but i want to be able to shut down both boxes. Is there a dual usb cable available or should i make one? Any suggestions on how to do this without having to purchase another UPS would be greatly appreaciated - 2 UPS for 2 NAS seems a little overkill for home use!
cheers
anthony
I do not own a QNAP, nor your type of APC UPS (Synology DS210j + APC BE700G).
From what I have read, both Synology and QNAP do support this, standard functionality. The USB connected NAS acts as a master, the other NAS as a slave. The IP address of the NAS slave must be known by the master NAS. If the master NAS is about to shut down, it signals -over LAN- to the slave. Of course the power of your router must be supplied by the UPS also then.
I do not use this setup, and can't test it: I own just one NAS.
What I did test, and it worked: The NAS, USB connected to the UPS as master, my laptop as slave (only connected by WLAN). This required installing a NUT client on the laptop. I found this info helpful: http://www.gadgetvictims.com/2010/02/battery-backup-solution-for-home.html
So, if this works, why wouldn't a two NAS setup of the same brand work? Your slave NAS doesn't need a kind of NUT client, its built in.
I hope this helps. Check out the QNAP manual, and the QNAP forum!
BillP Leader
Leader
hi anthony,
i am not aware of a way to get this to work on any Back UPS. For a Smart UPS, you might have a different option with a network management card but the Back UPS are designed to work with one direct connection. i am not sure if there is a way to get around that but i haven't heard of one in my time working with these products.
