RS 1500 G is only weeks old, 'Replace Battery' alarm this morning??
Select a Country
  • RS 1500 G is only weeks old, 'Replace Battery' alarm this morning??
BillP Leader
2150
144
Techie_apc
Techie_apc
83
gar37bic_apc
gar37bic_apc
Explorer
Posted: ‎2021-06-29 07:52 AM . Last Modified: ‎2024-03-21 04:36 AM
1327
We bought and installed this UPS just one or two weeks ago. This morning when I came in my coworkers told me that it was beeping and they pushed a button to turn the beep off. I somehow doubt that it needs a new battery yet.
Below is the output from NUT (Network UPS Tools) upsc application. My workstation generally runs about 140 to 170 watts, which is only about 20% load. So, what is wrong? What do we do?
Thanks in advance.
$ upsc apc
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 50
battery.date: 2001/09/25
battery.mfr.date: 2011/10/09
battery.runtime: 2205
battery.runtime.low: 120
battery.type: PbAc
battery.voltage: 27.2
battery.voltage.nominal: 24.0
device.mfr: American Power Conversion
device.model: Back-UPS RS 1500G
device.serial: 4B1141P49540
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.version: 2.4.3
driver.version.data: APC HID 0.95
driver.version.internal: 0.34
input.sensitivity: medium
input.transfer.high: 147
input.transfer.low: 88
input.voltage: 126.0
input.voltage.nominal: 120
ups.alarm: Replace battery!
ups.beeper.status: disabled
ups.delay.shutdown: 20
ups.firmware: 865.L3 .D
ups.firmware.aux: L3
ups.load: 18
ups.mfr: American Power Conversion
ups.mfr.date: 2011/10/09
ups.model: Back-UPS RS 1500G
ups.productid: 0002
ups.serial: 4B1141P49540
ups.status: ALARM OL RB
ups.test.result: No test initiated
ups.timer.reboot: 0
ups.timer.shutdown: -1
ups.vendorid: 051d
Techie_apc
Techie_apc
Contributor
Dear Gary,
the report which you pasted shows that the battery is installed. However, I would suggest you to check if the battery is installed correctly in the UPS. It is very easy to check. Pls remove the battery compartment door at the bottom and see if the battery cartridge is placed correct. Instruction label is pasted on the battery cartridge.
And also please check the exact message of the error of the LCD display to know what is the exact symptom. the user manual of the UPS has got the details of the LCD display messages which will be useful in identifying the cause of the beep.
If it does not work, then please contact the support team for warranty replacement of the battery if your unit is under warranty.
Message was edited by: Techie
Techie_apc
Techie_apc
Contributor
Dear Gary,
