Posted: β2021-06-29 03:00 AM . Last Modified: β2024-03-22 02:19 AM
I have a new BE750G which is working fine except for one problem. With the Master socket enabled, when I select standby, it does so. However, when the peripheral power clicks off, the computer promptly wakes back up. If I disable the Master, it goes to sleep fine, but of course all the peripherals are still on. It shuts down correctly. The computer is an HP Pavilion running XP Pro SP3, and the latest version of Parachute Personal Edition. Checking or clearing the "Allow this device to bring computer out of standby" in the Device Manager has no effect.
Treg
Posted: β2021-06-29 03:00 AM . Last Modified: β2024-03-22 02:18 AM
O Giant Techbrains, Are You Listening?
This post is a customer's amused view of the interaction among three outstanding products of our hi tech culture: the Imac computer by Apple, the Pixma MP830 all-in-one printer-copier-fax by Canon, and the BE750G uninterruptable power supply by APC.
When I received my Imac I already had the printer. I found that the Imac Tiger OSX had a feature that allowed me to point and click a command that would put it to sleep, after which pressing a keyboard key would reawaken it in virtually the previous condition. I say "virtually" because there was a delay while it reacquired its wireless network. The successor OSX has the same feature.
Because my printer could be used independently as a copier or fax I turned it on while the Imac was asleep. Whoop-de-doo! When the printer turned on it woke the computer. So I put the Imac back to sleep and completed my work with the printer. Then I turned the printer off. The computer woke up again! I subsequently learned to turn the printer off before I put the Imac to sleep but I frequently forget that and it has been a nuisance but a livable one.
When I called Apple tech support about this I was told, after about half an hour for consultations, that tech help can't do anything about that and that I should address feedback on the Apple home site. No doubt this feature was built into a much earlier version of OSX before there were so many all-in-one printers in use and it just got grandfathered into every subsequent release.
The best is yet to come.
When my old APC power supply shuffled off this mortal coil I bought the BE750G. This new unit had two interesting features. It had software and a data cable for connecting to the computer so that, in the event of a power failure, the system could be powered down gracefully before the battery power was exhausted. Great! I attached the cable and called APC tech help for further guidance because the software disk gave me some unintellible gobbledigook about obsolete versions of OSX. Tech help explained to me that the software only worked with those obsolete releases and that it would be totally useless to me.
The second feature is that there are three outputs of the power supply that are contolled by the "master" output to which my computer is attached. When the computer is off or asleep, any peripherals plugged into these outputs would automatically also be powered down.
Great! I tested this by plugging my printer into one of the controlled outputs. The following results were obtained.
1) When the printer and the computer were both off, I could not turn the printer on without first turning on the computer.
2) When the computer and the printer were both on and I turned the printer off, that seemed to work OK.
3) When I subsequently put the Imac to sleep, both machines remained off but the power supply began to make a strange noise about every 6 seconds. It sounded roughly like a drop of water falling upon a metal tray. Possibly, some component in it was switching on and off periodically. I found this noise very distracting.
4) After that, when I woke the Imac, I found it impossible to turn the printer on.
5) When I put the Imac back to sleep, I could still not turn on the printer.
6) When I woke the Imac again, the printer finally could be started.
7) With both the Imac and the printer on, I then put the Imac to sleep and something really remarkable happened. First, the Imac went to sleep, then the printer went to sleep, then both the printer and the Imac woke up again!
I have gone into survival mode by disabling that APC feature.
I hold Canon innocent in this madness. It is a perfectly good printer. But - - -
Apple and APC, are you listening?
Treg
Which devices have you checked the "Allow this device...standby" option on? I would check it for any and all relevant peripherals that are plugged into the unit and to the PC. We generally only support hibernate with our UPS systems, since sleep mode causes so many "wakeup" issues.
I traced the problem to an old Belkin powered hub. Old enough that it was only rated for USB 1.1, though that is plenty for what I have plugged into it. The problem is the hub itself. I can remove everything plugged into it, and the problem still occurs, and stops when I disconnect the hub. I can find the hub in the device manager, but unfortunately it does not have a power management tab. The USB port on the computer which feeds the hub has only the "Allow turn off of this device to save power" option. Any suggestions welcome, but it looks as if it is time for a new hub. π
Treg
Yea, that sounds correct. We generally don't support the use of hubs with our UPS' because comm issues like this, among other issues like loss of comm or inability to shut down, etc. You can technically get it to work but be prepared for at least an occasional "functional blip".
