Problem with CS 500, no power out when on battery.
  • Problem with CS 500, no power out when on battery.
2151
Spock Teken
106
83
Posted: ‎2021-06-28 07:18 AM . Last Modified: ‎2024-03-26 10:35 PM
388
Hi
These are the symptom's/steps
Remove power, amber light on, relay clicks, power output non existent.
Passes self test (which also results in no power out)
Battery changed, charged fully, self test passed, same issue.
Here is the info re the unit, with original battery.
Any Ideas?
Aimee
APC      : 001,045,1048
DATE     : 2018-08-15 12:54:14 +0100
HOSTNAME : gonzo
VERSION  : 3.14.14 (31 May 2016) debian
UPSNAME  : snoopy
CABLE    : USB Cable
DRIVER   : USB UPS Driver
UPSMODE  : Stand Alone
STARTTIME: 2018-08-15 12:51:10 +0100
MODEL    : Back-UPS CS 500
STATUS   : ONLINE
LINEV    : 242.0 Volts
LOADPCT  : 0.0 Percent
BCHARGE  : 100.0 Percent
TIMELEFT : 64.6 Minutes
MBATTCHG : 5 Percent
MINTIMEL : 3 Minutes
MAXTIME  : 0 Seconds
OUTPUTV  : 230.0 Volts
SENSE    : Medium
DWAKE    : 0 Seconds
DSHUTD   : 180 Seconds
LOTRANS  : 195.0 Volts
HITRANS  : 256.0 Volts
RETPCT   : 0.0 Percent
ITEMP    : 29.2 C
ALARMDEL : 30 Seconds
BATTV    : 13.7 Volts
LINEFREQ : 50.0 Hz
LASTXFER : No transfers since turnon
NUMXFERS : 0
TONBATT  : 0 Seconds
CUMONBATT: 0 Seconds
XOFFBATT : N/A
SELFTEST : NO
STESTI   : None
STATFLAG : 0x05000008
MANDATE  : 2016-02-10
SERIALNO : 4B1606P12973
BATTDATE : 2016-02-10
NOMOUTV  : 230 Volts
NOMINV   : 230 Volts
NOMBATTV : 12.0 Volts
NOMPOWER : 300 Watts
FIRMWARE : 808.q10 .I USB FW:q
END APC  : 2018-08-15 12:54:22 +0100
Hi
Yes that's the model.
How did I determine no output, the computer shutdown immediately, as did the display.
Any way its within the warranty period so its being swapped.
I reckon it may be the inverter
First one gone defective and I have been using them for over 10 years, got three on site,
and a very old/heavy serial one, still works.
Hi aim,
This is an interesting one. I'm assuming that this is the BK500IE with the IEC electrical connections. How have you determined that there is no output? Have you actually measured the connections with a voltmeter or is the equipment which used to turn on, not turning on now?
Secret Squirrel
Hi
