Posted: β2025-01-23 10:02 AM
I configured Serial Shutdown's email notification and hit Test, but nothing is coming through. Our mail server settings have been confirmed as correct by our hosting service. They - and I - suspect that either Windows Defender and/or ESET NOD32 antivirus may be blocking ports. Hosting service recommends SSL and port 465 or 587.
Nothing is being received regardless of settings. I do recall when I installed PCSS the installer asked for permission to unblock ports - which I did. I do not know exactly WHICH exceptions refer to PCSS in the Defender list. When it comes to NOD32, similarly, I do not know where or what the exceptions should be.
This failure to send was observer on 2 different Windows 11 workstations connected to 2 different SMC 1500C UPS units. Does anyone have any insight as to how to fix this?
Posted: β2025-01-28 03:47 AM . Last Modified: β2025-01-28 04:08 AM
It's very unlikely your ISP will allow SMTP access without authentication. Did you try enabling authentication and entering username (usually your email address) and password for your email account?
There might be additional error information in the application logs. You can find these in PCSS installation folder (usually "C:\Program Files\APC\PowerChute Serial Shutdown\agent\log\pcss.log").
PCSS, upon installation, only gives option to open TCP port 6547 for remote Web UI access and UDP ports for SNMP. This option is only shown if enabled Windows Firewall is detected. PCSS does not add firewall rules for SMTP.
Outgoing SMTP traffic on the default SMTP ports (25, 465, 587) should not be blocked by Windows Defender Firewall. Unless you added your own rules. If SMTP remains blocked it's probably your AntiVirus (NOD32), and you will have to refer to documentation on how to enable outgoing SMTP for it.
Posted: β2025-01-24 07:44 AM
I suggest you start by disabling both antivirus & firewall applications. Next provide the PCSS logs to see what error codes are being declared.
Lastly, provide an image capture of the SMTP settings while obscuring any PI data.
Questions Ask . . . π
Posted: β2025-01-27 08:06 AM
Thanks for your suggestions. The PCSS logs only show routine events (Both Data and Event logs). I assume you mean the logs available off the PCSS menu. Here is a screen shot of the e-mail settings. I confirmed the mail server settings with my ISP. Both firewall (Windows) and Antivirus (NOD32) switched off. I don't know how an "exception" might be specified in the NOD32 or firewall lists.
Posted: β2025-01-28 09:25 AM
It is now working! The problem was a mis-specification of the mail server on my behalf. The web host pointed it out to me when I sent them a copy of the last set of log entries to review. (Sound of palm hitting forehead...)
Posted: β2025-09-25 01:36 PM
The Log file is showing the following error message:
2025-09-25 23:18:37,434 [SMTPMailWorker] WARN - [SMTPMailer.SMTPMailWorker.()] Send failed :com.sun.mail.smtp.SMTPSendFailedException: 530-5.7.0 Must issue a STARTTLS command first. For more information, go to
530-5.7.0 https://support.google.com/a/answer/3221692 and review RFC 3207
530 5.7.0 specifications. 5b1f17b1804b1-46e2a996c03sm90129935e9.3 - gsmtp
Can you please advise?
Posted: β2025-09-26 12:10 AM
Retried this morning and received the following error message:
